OP
roadpacker
- Joined
- Sep 27, 2018
- Messages
- 12
- Tractor
- ford 1715,26000,3600,6600
Thanks for the information. I got the old original double seal out pretty easy,but I don't think I will find a double seal to go back with. My local NAPA store found a seal for the Ford 3000 with the Plessey pump, but won't know if it is a double until it gets here tomorrow.I am relieved to know that just one seal worked fine for you. I may have to do the same thing.Would putting one seal with the lip toward the pump, put the snap ring behind it, and then putting a second seal with the lip facing the drive gear work like a double seal?I think there is room to do that but the second seal wouldn' be captured by a snap ring. Maybe a drop of Loctite on the seal o.d.? I will measure the seal well tonight to see if 2 seals and a snap ring will fit. Thanks againHi Roadpacker,
I recently had the same issue on a '67 Ford 3000 and everything Harry in Ky says matches my experiences. To further the explanation, air is sucked into the pump, likely thru a shaft seal and foams the oil, increasing the volume until it spews from the filler.
My reading and observations found that the double seal was to allow the inner one to seal the oil and the outer one to exclude dust. My kit also lacked a double seal and I could not fit two in the space provided, so I installed one with lip facing inward only. It works fine.
Hardest part of the job is the cleanup before opening it. The orings will become self explanatory. Beware of scoring the shaft seal seat getting the old seal out as I did. Luckily it still sealed.
