1975 1120 injector pump advice
   / 1975 1120 injector pump advice #1
espacef1fan
Shopping for a tractor
I have a 1975 1120 and the injector pump is leaking. The local diesel shop said it is a “CAV” type unit and would rebuild it for $400-up depending what was wrong. He said buying new was stupid expensive but I’ve found some new pumps that claim to fit for $600 or so but I’m unsure of their compatibility because my pump has no data plate visible(while installed anyways?)
I’ve attached a few pictures and I’m hoping someone here can tell me more about what kind of pump I have.
   / 1975 1120 injector pump advice #2
If you carefully remove paint on plate attached to your tractor's IP you should be able to read pump ID info. JD did sell aerosol paint remover that would remove the paint. JD part # is AR91772 which cross references to DPA3432F530;
   / 1975 1120 injector pump advice #3
TxJim is correct.. The circle is the name plate w/ all the info u need to search the pump..
I will send u an pm or email..
But why would u spend 600.00 vs 400. + ??
EMAIL sent.
Any advice on how to remove the paint?
I’m
Going to attempt some light scraping with a razor blade but not sure where to go if that doesn’t work
EMAIL sent.
He said that price starts at 400 but made it clear that if he found no old/worn parts in my 40 yr old pump.......
So did some gentle wet sanding and it seems stamped
I’m unsure which is a model number or otherwise.
The bottom number seems to have a number finished with an etch tool suggesting it’s a serial number.
Here are the numbers best as I can read them left to right , top to bottom.
343290
58 800 5 2675
0928920????
   / 1975 1120 injector pump advice #7
WALMART has spray stripper IN A CAN.. GET SOME.. spray it on, wipe it off..
ANY parts house will sell it..
Your missing a #.. 343290 is the pump #..
Went after it with some stripper
No other numbers
   / 1975 1120 injector pump advice #9
Look closer.. CAV pump #'s have 7 digits.. could be 900.??
   / 1975 1120 injector pump advice #11
There ya go.. ya got it..
so now u have the pump #..
So now u have some options..get a new one or get yours rebuilt.
   / 1975 1120 injector pump advice #12
Diesels seem way too expensive to bother with. the injection pump is the main problem, it's crazy expensive to even have it looked at!..
Do you have any vendors you would personally recommend for a new one?
   / 1975 1120 injector pump advice #14
new is new.. weather its aftermarket new or oem new.. OEM new will cost in the 1000.00 range
but why would someone opt to spend the money for an aftermarket new pump,{600.-700} when they can have the original
pump repaired for 2-300.00 less.??
Most people only do that if their pump is deemed unrepairable..
I know folks that have opted to fix their original pump, even tho it will cost the same as a new aftermarket pump..
   / 1975 1120 injector pump advice #15
Really? I've been custom farming/baling since 1987. I've rd baled over 150,000 rd bales, plowed/seeded unknown 1000's of acres while owning 8 different diesel powered tractors. I had to have 1 inj pump resealed about 30 yrs back & I have another inj pump on a tractor that has about 13,000 hrs of use that needs resealed today. The secret to inj pump life is to """keep fuel clean"""!! I filter fuel before it goes in tractor fuel tank & change tractor fuel filters.
   / 1975 1120 injector pump advice #16
Consider the source of that information.
   / 1975 1120 injector pump advice #17
Agree with "fried1765" 's comment. (as well as Tx_Jim 's ).
Late update.
Awhile back I got a quote locally to fix it.
$800
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Crown RC5535-35 Stand-On Electric Forklift (A59228)
Crown RC5535-35...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2018 Deere 323E (A53317)
2018 Deere 323E...
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
Eagle Weathervane (A55853)
Eagle Weathervane...
