1975 GMC 6500 dump truck with 366ci gas big block
   / 1975 GMC 6500 dump truck with 366ci gas big block
Well, I've now made about 20 trips to the local materials yard with my old '75 dump and I have to say it's starting to earn it's keep. I have one rather large hill (we don't have mountains where I live, but it's as close as we do have) between me and the yard. I could go around it, but it adds about 20 minutes per trip. As long as I don't get in a hurry, the old 366 gasser will pull the full 9 1/2 tons it will legally haul and keep up with the speed limit. :thumbsup: I could probably haul another 4 or 5 tons more, but it would be illegal and I figure why chance tearing up a good old dump that runs, drives, stops and pulls just fine. I might load more soil in it when I move dirt short distances around my place, but that would just be crawling around in 1st gear.
I did have the king pins replaced when I had all the brake job done and now it pulls to the right a bit. Anyone think there'd be any problem if I just used a tape measure to line it up? I'm not going to be driving it all that much, but pulling like it does now will kill my front tires in short order and they are the good tires on it.
   / 1975 GMC 6500 dump truck with 366ci gas big block #73
For no more than you drive it you could get it close enough. Be a different story if you were making a living with it. Make sure all the tie rod ends and ball joint are good or you are just wasting time. But you already know that.:D
Chris
   / 1975 GMC 6500 dump truck with 366ci gas big block #74
Dargo,
Well a year later and how is the dump truck holding up?
I enjoyed you thread and am debating buying a older dump truck for occasional use.
   / 1975 GMC 6500 dump truck with 366ci gas big block #75
I doubt you'll get a reply because I think Brent has been AWOL since he got into some kind of debate about using diesel fuel to protect metal from rust (pretty serious stuff, obviously).
   / 1975 GMC 6500 dump truck with 366ci gas big block #76
Thanks for the info.
Best to avoid heated debates on the net.
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
Deere 316GR (A50123)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53473)
2011 New Holland...
