i have a construction king 480d/ll front loader/skip drag. i have pulled the control valve and had it rebuilt at local hydraulic shop because there was fluid coming up through the steering wheel. i had the steering rams rebuilt, they do not appear to be leaking. also replaced the power steering pump and there is still no lock to lock steering and it turns endlessly. feels like it’s bypassing still. if i lift the front itll turn barely. if theres weight on it the wheels barely wiggle. there is hydraulic fluid in the main res, and i put 15w40 in the power steering pump that was recommended in it because i guess if it craps out it can get into the engine. i do not see any leaks. theres a little bit of oil on the steering ram shafts but not much since theyre were just rebuilt. theres oil residue kinda everywhere since it’s old. but am i missing something? if there was air in it would it work itself out if so how long? should i try to bleed fluid from the hose on the rams? seems like theres no hydraulic assistance at all. i think i pretty much rebuilt or replaced everything. only thing i can think of is maybe get new steering rams or have a faulty valve rebuild or powersteering pump. again i dont see fluid pissing or bleeding anywhere. whatelse could be going on
