1992 Toro 30935 Leaf Blower carburetor question
   / 1992 Toro 30935 Leaf Blower carburetor question #21
In the realm of cheap & easy, try soaking the carb in carb cleaner for a few days
Won't work if the pump diapragm is hard and I bet it is. You could soak it for a year and it won't change and it's easy to replace. the cylinder has some score marks in it (in the picture) but not deep so it should run after you do what I told you to do in my previous post.
   / 1992 Toro 30935 Leaf Blower carburetor question #22
Have you looked on Amazon? A bunch of rebuild kits came up for Walbro carbs, none for the numbers you have but I bet one of them is correct.
Again, be very careful with Amazon. Lots of Chinese sub par parts on there. You have to look beyond the cheap price most times.
I'm a big 2 stroke person, especially chainsaws and I love to hop them up as well. I don't own one saw that I haven't modified in some way for more grunt. Just bought a new Echo CS590 Timber bear and it came apart before I started it the first time Put an offset crank key in it, new magneto module (Echo speed limits the saw through the mag coil), modded the muffler, removed the restrictor plate and installed a Stoekel Oiled foam air filter and velocity stack. The stock dry fuzzy (Stihl clone) are filter leaks fines plus it's restrictive. I will at some point put a larger throat Walbro pulse carb on it too. Stock, it's carb restricted but workable. I need to save my pennies, a new Walbro ain't cheap. I want it to pull a 24" full chipper .325 chain and not have any issues. Stock, the best they can do is a 20" skip tooth .325.
I was hoping you knew! It looks like you had someone step up and tell you which one.
As a rule I rebuild carbs mainly because I’m cheap. I bought a new one for a Lawnboy 2 stroke and it didn’t go well, it over reved. I ended up remembering someone in the comments section of Amazon where I ordered the carb said he had to switch a jet from the old carb to the new one to make it work. That worked for me too. Most of those carbs are simple so a rebuild should fix it if the carb was the problem.
I rebuild carbs because I am cheap, and I actually enjoy it. I rebuilt my first carb about a year after I got my first car (1975 Chevy Impala 2-door), a Rochester 2GC.
BUT YOU HAVE TO KNOW WHICH KIT 😁
I have heard that soaking stiff pump diaphragms in brake fluid for a couple days will revive them. I have not had the opportunity to test that yet.
I have five Homelite SuperXL12 (two not in use currently, one is parts) — in addition to my primary saws (Dolmar 6400, Dolmar 7300, Ecco 132). The Homelite was my first “real” saw, and it is a reliable backup. Not a fast saw, but torquey enough to pull the chain through most anything.
Any suggestions on hopping one of those up?, since I have a couple to play with?
   / 1992 Toro 30935 Leaf Blower carburetor question #26
Parts will be a crapshoot at best. The old 'homies' as well as the old Polans and Macs are getting harder and hard to get parts for today. What I do if I do pull a jug is, I remove the base gasket and put a smear of Kubota 3 Bond the base and retorque it but I do measure the after compression ratio to make sure it's not to high, squish is everything.
Easiest and least intrusive mods are of course the muffler and the intake tract (larger carb) and better and less restrictive filtration. Builders all tend to cheap out on air cleaners and undersize throats on carbs as well as restrictive. The more air in and the easier the exhaust exits, the better response you get without major dissection. Stoekel makes some nice air filter / velocity stack combo's and you can buy direct from him btw. Nice guy. Most production saws also have rough exhaust ports and transfers that always can stand smoothing out but that entails removing the cylinder and pulling the piston which can be involved and requires re-torguing the head bolts. Just as easy to modify them externally most times and Nick sells the 5 degree offset flywheel key as well. I like to advance the timing 5 degrees, that always 'wakes up a saw' in my experience but some saws require a special puller to remove the flywheel and remember the flywheel nut always loosens the opposite way the flywheel rotates.
Finally, I always remove the limiter caps on the carb jets (if they have them) because Echo especially sets the mixture rich which causes 4 stroking when cutting but, be cognizant that being a 2 stroke engine, they are prone to seizing if you lean them out too much. I like to adjust the high speed jet just a little, run the saw (in a cut) and then pull the plug and observe the color. Needs to be light brown not white and I'll kill the saw immediately after the cut so the idle jet don't give a false reading. I know you should always cool down the motor after working it and I do, same with starting a saw, I allow it to idle for a minute or so to let the cylinder and piston to reach operating temperature prior to working it. I do the same with my vehicles as well. Thermal shock greatly lessens engine life. I must do something right because my 45 year old 028 Stihl runs like a top (modded muffler only) and cuts like a bear (with a sharp loop). The o28 I own was only built for 2 years and then discontinued. It's an RPM saw and an earmuff required saw and it screams. Too bad Stihl quit making it. I also own a 090 and 075 I bought them new when I bought the 028. Both are in pristine condition and the 090 wears a 4 foot buddy bar while the 075 wears a 28 inch bar and both have full tooth (not skip tooth) 050 chains with Stihl greaseable roller nose bars. Even though both are magnesium cased, no plastic, both are heavy, too heavy to actually use for cutting at my advanced age. Not a square tooth loop fan. Fine for milling but I don't mill and square tooth has to always be hand filed too.
I keep syn gas in both and fire them up regularly. Both have compression releases. You never try to start either without it or you'll leave your fingers on the recoil handle. They are wicked saws. In fact I run syn gas in everything. No e-gas here. I like the Echo Red Armor but it is hard to find in gallons so I also use Tru-Fuel in 50 to 1 for the modern saws and 40 to one for the older ones and I always use either Stihl bar oil or Menards brand, never used motor oil, never. Used motor oil don't have the tackiness required to not fling off and it's usually loaded with contaminates including microscopic metal chips, none of which is good for your saw, especially the chain and drive sprocket and I watch the drive sprocket for wear as well. Almost all of them have wear indicators today so when the chain wears it to close to the wear mark, I replace it. A worn sprocket also wears the drive tangs on the loop quickly. As usual my post is a bit long but I don't mind telling you or anyone else interested what I do and how I mod my saws.
I am printing this FFR 😁👍
I have been using VP PreMix for my “new” saws but the old beasts get pump (no eth) gas mixed at 32-1. I am probably going to switch everything over to no-etch pump gas because $26/gallon is getting a little rough…
I use the TruFuel oil and Makita Bar Oil. I like the Makita oil - it is quite tacky and I also use it as way oil on my lathe.
   / 1992 Toro 30935 Leaf Blower carburetor question #28
I don't because it lacks the proper boundary lubricant. I use Shell Vactra 65 VG way oil or Bridgeport way oil, but then my machine tools are used daily. Most if not all synthetic flood coolants have boundary lubricants included in the mix as well. I use Trim synthetic water mix flood coolant and mix it according to the recommended dillution ratio or use my Brix fractometer to determine the concentration The issue with using any way oil on a flood coolant machine tool is you have to also have a tramp skimmer in the sump to get it out and deposit it in a suitable container and they ain't cheap either. So I don't as a rule except on the high precision surface grinder because the vee ways as well as the ball ways on the table never see any external flood coolant. They get pressure lubricated via a manual injector, just like the Bridgeports do.
My lathe is used on a hobbyist level on occasion, and it has no flood coolant.
Heck - I store and run it in a surplus army tent off a 150’ of extension cord from the house 110v! Flat belt machine, to boot…
   / 1992 Toro 30935 Leaf Blower carburetor question #30
I have one of those as well. A fully restored South Bend bench top lathe with a quick change gearbox, collet closer, a full set of 3C collets in a hardwood sequestered box, 4 jaw chuck, 3 jaw chuck, face plate dog plate and even an Aloris AXA quick change tool post with a complete set of tool holders. Took me over a year to restore it. Bought it in Cleveland from a defunct job shop. Was sitting in the corner, filthy and I paid 100 bucks for it. Irun Aloris tool posts on all my lathes, like with anything, you get what you pay for.
I also have a fully restored South Bend cabinet shaper that just sits but I liked it when I saw it and it was local so in the back of my pickup truck it went. It was a bit more than 100 bucks, more like 500 but restoration was easy and they are very, very rare. Lots of Atlas cabinet shapers on Flea Bay and elsewhere and most of them are beat to hell and restoring the ways and hand scraping them is a real chore plus beating on them destroys the back gears and the ram travel.
2 LeBlond Servo Shift large, spindle bore lathes, 2 bridgeports, one Versa Trak one series one, a Kent ultra high precision tool room surface grinder that can hold 50 millionths, a Lodger and Shipley hydraulic arbor press (30 ton), a mint condition Atlas (Kalamazoo) floor lathe (Im the second owner, the first was my late uncle who willed it to me) fully tooled but I retained the lantern toolpost because it came with a full set of Williams tool holders, like I said, everything is fully tooled and I and my 2 part time employees use them all, and I demand respect for my machines or you don't work for me anymore. I also have an overhead crane that runs the length of the shop. It's an IR air operated chain hoist on an IR trolley, 5 ton capacity. Main use is changing the oil in my bikes so I don't have to get on the concrete floor which is heated with in floor PEX heat and air conditioned in the summer. Various welders in all disciplines as well a computer controlled Hyper Therm plasma cutter and a CNC plasma table, I find it easier and cheaper to cut my own parts from sheet steel. Took me over 30 years to amass all of it, many auctions and many trips to Dessil Tool in Lansing and Detroit for new machines and tooling.
That and 2 large frame Kubotas and all the hay tools, spreaders both granular and liquid, 90 inch Lucknow snowblower, loaders for both plus 3 buckets and a stump grinder, new round baler and a 3 year old NH discbine and a Kuhn Masterdrive rotary rake single rotor I just bought (sold a twin rotor) on Tractor house and broke even 2 shredders, one an 8.5 foot and the other a 15 foot bat wing, front mount repurposed commercial snow plow with power angle welded to a bobcat style hitch plate (both my tractors have SSQA's) One is aa deluxe cab model, the other is an open station. I got a lot of stuff and a hefty insurance bill as well. That don't include the barns or the 2 rentals I own or the cars or trucks or the Kaufman 28 foot GN and it's 99% paid off. including the farm and it's 142 tillable acres.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
1273 (A50490)
1273 (A50490)
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
Electric Mobility Scooter (A54815)
Electric Mobility...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
