1st gen Toyota Tacoma question
   / 1st gen Toyota Tacoma question
No go. I quit my job Saturday. Maybe next month if I can't buy something that'll work.
   / 1st gen Toyota Tacoma question #14
I would recommend that you buy a Wilson5000 magnet mount and get it over with.
Mounting CB antenaes on corners of vehicles at best if your swr are low puts you recieving and transmitting directionally.
Mounting an antanae square on roof with your swr's low puts you omni-directional.
Big rig over the road trucks obviously can't mount or most won't mount antenaes on roof.That why lots of them run dual antenaes(one on each mirror)for better reception/trans and also makes rigs look sharper.
Boone
Back from the dead. I measured the height of the bracket, came off on a 45, and made a 2.25"x2.25" square for the antennae to bolt through. I then left about a 3/8" gap between the body of the truck and the back of the square plate. The stock I used was stainless and the weld was gonna be small, so I carried it across town to the good welding shop. Had him make a pass on each side of the angled piece and then I carried it home to make the holes. The antennae is one I had back in 1994 and is used for mock up purposes. I plan on either a shorter black one or a steel whip. The rust is from a previous bedliner and is to be addressed when I get back home. I picked up a Cobra Ultra III that is going to get peaked and tuned when I get the new antennae. I unscewed the ashtray bracket and mounted the CB in this hole.
I don't really need or use a CB, but it sure would be handy had I had one in the past; next Katrina, winter storms (seem worse the further south they are), interstate traffic jams.
   / 1st gen Toyota Tacoma question #18
looks good!
What size are your BFG's?
I got 33's on mine with a OME ~3" lift
looks good!
33/1050-15s. It's about 2.5" lift. I've got some OME 880s, which are 1.25"+/- for a v-6, on a 4 cyl. New 5 leafs in the rear with some 1" shackles. Still hasn't seen the mud since I put all this together around March. :(
   / 1st gen Toyota Tacoma question #20
Yours is almost identical to mine:thumbsup:
What are you running for wheels? Im using the factory15's but need something with deeper offset. I have a bit of rubbing at full lock.
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
