1st gen Toyota Tacoma question
   / 1st gen Toyota Tacoma question
I bought the truck used in '02, it's a '99. The PO had a set of 15x12 Mickey Thompson Classic IIs on it with some 325/60-15 BFG ATs. Meats. It'd catch a groove on the road or highway and I'd have to two hand the steering wheel to keep it straight. I road the ATs out and put some KMs on it, same size. It rode 100% better, but now you couldn't hold a conversation when driving. Rode that until the first of the year.
I've got these 33s on a set of Cragar Soft 8s that are 15x8. I can't remember the backspacing, but I had to put a 1/4" spacer up front to clear the calipers. I got them from DiscountTire online to my doorstep, mounted and balanced, for a little over $1000. It was more than I wanted to pay, but the warranty is outstanding and I definitely wanted a narrower wheel from now on.
Now, if you'll google "Tundra Brake Conversion" you'll find that you can direct bolt up a set of larger Tundra calipers using your Tacoma rotor. They're slightly larger and require a 16 or 17" wheel. It has a bigger piston and more brake pad. If you're interested. Had I found that first I would have gone with a larger wheel, but 15" tires are way cheaper anyway.
   / 1st gen Toyota Tacoma question #22
I was thinking MT classicII's. Not sure what im going to get. spacers are an option. Id like to keep it factory toyota if i can. I wonder what factory rim has the deepest offset in that bolt pattern? Probably not much different from the factory then what i currently run.
The black steelies I got were about $45 USD each. IIRC, the Mickeys run about $120. I think there are 2 variations of BS per wheel size. Summit and Jegs carry a good selection to get an idea. TTORA, IH8Mud, and ToyotaNation are decent forums with good data bases.
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51246)
2014 TAKEUCHI...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
