2 bottom plow Ford 101
   / 2 bottom plow Ford 101
Thanks folks, lots of good information. I will take a pass on this one, but know more about plows now.
   / 2 bottom plow Ford 101 #12
If your 3 bottom is setup like the 2 bottom in the picture (about level across the hitch, pin to pin) Then in order to get the plow to run correctly, you may need to screw in your tractor right leveling box assembly quite a lot. The plow should be level with the ground, left to right and front to back after the right tires drop down in the furrow on the second pass. Ken Sweet
That's what the Top and Tilt is for. Works great for adjusting the plow to level.
The photo is of the three bottom plow just the third bottom is out of the frame.
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2016 Kubota SVL75-2 (A50123)
2016 Kubota...
John Deere 5075E (A50123)
John Deere 5075E...
2020 EZ-GO EXPRESS S4 GOLF CART (A51247)
2020 EZ-GO EXPRESS...
2020 CASE IH 110N LOT NUMBER 206 (A53084)
2020 CASE IH 110N...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
