2 way radio antenna question.....
   / 2 way radio antenna question..... #11
Just use a Meter to check continuity, the center of the top of mno, and the center of the other end of the cable, also, check for short, across the two poles, and then if that works out ok, when you get your ant. check SWR's .
   / 2 way radio antenna question..... #12
Junk,
A <font color="red"> Factory </font> AM/FM/8track/CB radio! /forums/images/graemlins/confused.gif OK, now I'm curious, if you don't mind me asking, just what make / model is this?
Mike
   / 2 way radio antenna question..... #13
Junkman, You might get better results from 1 anttenna with this and a nice CB antenna than with the AM/FM to cb combo... Sorta more CB orented. Can't be worse I would Hope. CB/AM/FM Spliter I have been considreing something like this to use on my 96 Exploder.. As it has no practical place for a traditional CB antenna. I thought I might replace the AM/FM one with a nice Wislon 24" cb antenna and this do hicky... My only consernc is it makes no mention of a max power rating.
   / 2 way radio antenna question..... #14
<font color="blue"> just what make / model is this? </font>
If he says it's factory, it must look like the attached picture of a GM Delco unit.
Lawrence
   / 2 way radio antenna question..... #15
Here is a picture of a Mopar unit.
Lawrence
The car is a very limited production 1978 Cadillac..... They only built 30 of them... 10 each year for 1977 - 78 - 79..... 4 tons of a All American made beauty.... I call the "Great White Whale"....
   / 2 way radio antenna question..... #17
PBMAX,
CBs are limited to 4 watts (or is it 5) at any rate, all the mobile units should be rated for the same wattage, so it SHOULD be rated correctly. Of course, if you're running an illegal linear, then you'll probably fry the AM/FM.
Mike
   / 2 way radio antenna question..... #18
Junk,
Wow, I graduated HS in '71, so you'd think that I would have noticed combo units like that. I really don't remember ever seeing one though!
Thirty cars, that's pretty rare! Hopefully it's in good condition. Sounds like it's worth something. Good luck with it.
Mike
It needs to be repainted, but the car is solid with only surface rust from stone chips. It has 19,000 miles on it and I know that the mileage is correct for a variety of reasons. I am the 3rd owner, the first owner was in Saskatchewan Canada, and the second one that I purchased it from was in Northern Alaska. When new, the cost was over $26,000.....
   / 2 way radio antenna question..... #20
mwechtal, used to have a amp but even if I wated to have one in this truck there is no practical place for it. Besides, I use it for traffic and radar reporting... 98% of the time so i could care less about kicking it up...But It does have SSB and the puts out 11watts in that mode... and thats what I was conserned with. What would happen to the AM?FM? if I used the SSB. So I emailed one seller to see what they say the power rating is. If they respond I'll post it in case any one else is intersted.
199049 (A51243)
199049 (A51243)
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
