2001 chevy 2500 died, need ideas
   / 2001 chevy 2500 died, need ideas #11
.. A 6.5 has a lift pump mounted in the fuel line about the location a fuel filter would be under the truck driver's side.
Are you shure about that. I have been under my 3500HD for the last 2 days changing the trans. and havent seen one. I do know where the blank filter is along the frame and there in no pump there. I will look in the morning when I finish the trans.
   / 2001 chevy 2500 died, need ideas #12
Hooked - curious about your tranny fix? Allison give up the shift? Thanks.
AKfish
   / 2001 chevy 2500 died, need ideas #13
What are you calling a blank filter?? The inline lift fuel pump looks like a regular inline filter on a gas burner,, but on the 6.5 diesel there should be 2 wires coming out of the thing that looks like a filter. A fuel filter for a gas burner will go into the spot where the lift pump is. The treads on the fuel lines and the distance between the fuel lines on a 6.5 diesel powered truck, are the same for a gas burner fuel filter, meaning you can very easily think you are looking at a filter when in fact it is a lift pump..
   / 2001 chevy 2500 died, need ideas #14
Hooked do you have a 6.5 liter or the 6.6 duramax?? Seen the other post about allison transmission. As far as I know the trans behind the 6.5 is a 4L80E, where as the 6.6 has the Allison trans behind it..
Soundguy keep us up on the fix for the problem.
Will let you know when i hear back from the diesel injection rebuilder.
soundguy
   / 2001 chevy 2500 died, need ideas #16
My brother called me last night.. he has a chevy 2500.. he parked it on a job last night he was working on.. went to leave last night.. turns key.. nada. Has lamps and dash lamps, had starter a couple times.. then nothing.. no starter even.. not like dead battery.. just won't engage anymore. never even tried to catch the couple times the starter kicked.
any ideas where to look? ignition switch / start switch problems... I don't know how the injector pump on that vehicle is handled but assume the computer has it's hands in there somewhere..
soundguy
I don't know if this is a newer silverado or not. But the newer ones with the built in security will at times lose their minds. The result is bright lights, loud radio, PW working just fine ---- but turn the key and nothing spins under the hood.
jb
2001 .
soundguy
   / 2001 chevy 2500 died, need ideas #18
Morning Soundguy,
On some of the Chev's the lift pump is under the driver on the inside of the frame, this lift pump is controlled by the oil pressure switch for safety. It is a know problem that the oil pressure switch has to be changed on some of these. The truck will run without the lift pump but if it looses prime for any reason it won't run. You can jump the pump to test this. Don't know if this will help but hope it does.
I had a 94 Suburban with a 6.5 turbo, so I don't know how much this will help you.
So far they have repalced the charge pump, and while it was in they also found one bad injector... so they are changing that as well.
soundguy
   / 2001 chevy 2500 died, need ideas #20
AKfish, I have the 4l80E behind the 6.5. The 6.5 harmonic balancer took a crap (common problem) and before I found it, it had taken out the torque converter. It would kick out of overdrive after driving about 5 miles. Some how the computer monitors engine rpm verses input shaft and if it detects to much slippage it puts the trans into default.
Bill
2011 RAM 2500 (A53843)
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
