2002 Ford 350 5.4L dually dump towing
   / 2002 Ford 350 5.4L dually dump towing #31
Interesting to me that same frame, same springs, same axles, same brakes, same tires, and change either the engine or transmission changes the weight a vehicle can haul or pull safely.
My common sense tells me it has NOTHING to do with safety & everything to do with performance.
If I'm loaded heavy, I am usually not in a big hurry anyway.
   / 2002 Ford 350 5.4L dually dump towing #32
That motor has been around for a long time. If you are not going to be pulling 10K behind it everyday, it will be fine. The ones with the 3.73 rears are designed for the landscaper guys who pull 5-7k mower trailers around all the time and they do fine with that.
   / 2002 Ford 350 5.4L dually dump towing #33
Being able to safely pull out and merge with traffic or pull uphill with out slowing down too much are important as well, being too slow can be unsafe
   / 2002 Ford 350 5.4L dually dump towing #34
Ever notice that states require slower speeds for overweight loads?
   / 2002 Ford 350 5.4L dually dump towing #35
I don't know if this helps any..... 2016 Ram 3500 with a 6.4L gas engine and 4:10 gears. Pulls it pretty good and sucks gas while doing so. :(
Nice looking set up! You have an extra liter of displacement (6.4 vs 5.4), and lower gears, plus I think my motor is single overhead cam, the newer motors may have DOHC. Is that an 18 foot trailer? Boomer 35 / 40 tractor?
I think both - consider if it has 4.10 gears vs 3.73, you would get more engine braking power I would think. I'm with you, slow and steady with a heavy load.
   / 2002 Ford 350 5.4L dually dump towing #38
It is a 24 foot trailer and a Boomer 45 tractor. Tractor with loaded tires and backhoe weighs about 7000 lbs.
   / 2002 Ford 350 5.4L dually dump towing #39
i drove a f250 of that vintage w/the 5.4, but a 5spd, 2wd for a large equipment rental yard. i towed 12k loads with it daily. it did fine and never felt unsafe or underpowered. the local new holland dealership has a fleet of 5.4 powered trucks they pull goosenecks with delivering some fairly large machinery
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
More info coming soon! (A50323)
More info coming...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Mack CXU613...
