2004 BX1500 engine randomly dying
/ 2004 BX1500 engine randomly dying #1
twisted_pair
Ontario Canada
Kubota BX1500 (2004)
This first started a couple of weeks ago while cutting the lawn for the last time this season. The engine would randomly die for half a second or so then resume. It did this maybe 4 times in the last 30 minutes of work. It only did it while the lawnmower was operating, so I figure it must be a faulty sensor switch in the PTO.
Yesterday I had the front end load attached and was not using the lawnmower deck and it died once, but I was not using it for long.
Like a good ex- farmboy, I've had the seat presence sensor disconnected for near 20 years now.
I'm sure it must be a sensor failing for poor connector contact after nearly 20 years old. I'm an electronics guy who spend 50 years troubleshoot systems far more complicated than this, but a wiring diagram would help. Is there a downloadable wiring diagram for the BX1500 available on-line? Since its an intermittent random event, I may need to connect a datalogger to capture what is happening when the event occurs.
Bruce
/ 2004 BX1500 engine randomly dying #2
My gut feeling (and owning a 20+ year old BX2200) is the shut off solenoid.
I'll PM you a link to the BX2200 service manual. Should be real close.
The BX1500 shut off solenoid I believe works backwards from your BX2200 and most. To shut-down, the solenoid is activated for about 10 seconds to pull a shut-off valve, where most others the solenoid is activated to allow the tractor to run, and deactivated to shut-down.
/ 2004 BX1500 engine randomly dying #5
Question first: When it dies is it a slowing down sputtering death OR is it immediate and sudden and final?
JOHN DEERE HX15 BATWING ROTARY MOWER (A64278)
JOHN DEERE HX15...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2004 Chevrolet Trail Blazer 4x4 SUV (A64557)
2004 Chevrolet...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
