8561 said:
If you haven't done a steering shaft at 42,000 on an '04, you're one of the very few. You'll hear and feel a clunking in the column. If my memory serves, it has something to do with the routing of the exhaust that causes additional heat and negatively impacts the greasing in the column.
Can you tell me more about this problem my 05 Silverado has the bumping column .. is there a way the owner can lube it or does it have to be replaced?
The intermediate shaft problem is well known and documented. You should have no problem getting your 04 or 05 trucks fixed for free by the dealer.
Like someone else said the fix initially was relubricating the shaft, but I have heard they are replacing them now. In fact on my 2003 1500HD I have had my truck in 3 times for this issue. Supposedly they replaced the shaft the last time it was in - time will tell.
If you do decide to fix it yourself, the fix is not too difficult. Check out some of the Chevy truck forums and do a search on this subject and you will have plenty to read. Below are a couple of links
FULLSIZEforums - Chevy Truck
www.gm-trucks.com/forums/index.php?http://www.gm-trucks.com/.
