2005 BX 23 HELP
/ 2005 BX 23 HELP #1
nordic95
New Jersey
BX 23
OK so i have this tractor since new. Last year tractor started to shutter under load as if brake was on. I posted here and everyone said to check fuel and hyd oil system.So I did all that over the year and its just getting worst. Today is wont even push the slightest bit of snow and if I rev engine it wont even move. Like as if I put in neutral. If I lower throttle it will move but barely. I changed both fuel filters, blew out fuel line to tank. Changed hydro oil and filter, cleaned screen. Found nothing dirty or clogged. HELP... what could it be?
Thanks Anthony
/ 2005 BX 23 HELP #2
Does it seem to you a engine problem or a trans problem?
/ 2005 BX 23 HELP
It seems like a trans problem. Motor runs fine and never smokes or dies down at all. Sounds like a pressure relieve valve or something going on in trans. Its the noise I would get when in High gear trying to move a load. Now it does it all the time even in low.
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
2004 INTERNATIONAL 9400 T/A DAY CAB ROAD TRACTOR (A63291)
2004 INTERNATIONAL...
CATERPILLAR D5K2 LGP CRAWLER DOZER (A64279)
CATERPILLAR D5K2...
Freightliner Columbia (A63689)
Freightliner...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
KBH PT 12 Row Liquid Fertilizer Applicator (A64119)
KBH PT 12 Row...
