2013 Tundra vs 2013 Ford
   / 2013 Tundra vs 2013 Ford #131
No CEL. Im guessing its a COP because i have a bit of rough idle. Ive changed several cop in the past for the same driving symptoms. Havent dug into it yet, but im not losing any mileage because of it, its ALWAYS had bad mileage. 18mpg, consistently since new.
This could be an EGR problem. Valve stuck open a bit.
Usually a bad coil will show up when loaded while locked up in high gear. The fuel mixture is still pretty lean and if you can load it to just before it downshifts. That's always been the best way for me to find a coil that hasn't quite quit on me yet.
aczlan said:
It depends on your definition of "securing" ones load. I have seen far too many loads of 2x4s "tied down" with the poly string from Lowes to trust my fellow drivers to have the sense to properly secure a load.
Aaron Z
Agreed. I am being optimistic, hoping since he chose to haul it this way he would secure it properly. You never know these days.....
   / 2013 Tundra vs 2013 Ford #133
Yeah when I get it in the shop, Ill be sure to check EGR. Wouldnt surprise me if it was crudded up.. Ill also pull any pending codes.
Got to get the Toyota finished first though
   / 2013 Tundra vs 2013 Ford #134
Sounds like a lot of the problems are related to driving in salt.
Sent from my Samsung SPH-L710 using TractorByNet
Ford knows their trucks are driven in salt! **** they are head quartered in Dearborn Michigan! Just bad quality and bad engineering.
   / 2013 Tundra vs 2013 Ford #135
See if you can view any live data. DPFE should read about 1v at idle. Also check and see what baro reads in Hz. A bad MAF can cause a whacky idle that may not show up in other conditions.
Draw a vacuum on the EGR valve and see if
It either dies or stumbles.
   / 2013 Tundra vs 2013 Ford #136
Its gets regular maintenance.
Just various things are failing. Much of it has failed before and this is its second replacement. Bad design from the factory. Many problems Im having are very common on the ford forums.
This is the second time for fixing leaky exhaust manifolds. I probably should have bought new headers last time, the factory ones are garbage and warp, but it wasnt in the budget. Now its time to pay the piper. Known issue.
This is also the second rear end. First one was near the end of warranty. I think they just rebuilt it with new internals. Who knows if they set it up right? But they are known for eating pinion bearings, and thats what I have to fix now. Known issue.
Driveshaft (rear) is out of balance because ford used a ****** way of mounting the weights to an UNPAINTED! driveshaft. Rust gets behind the weights and pops them off. Another known issue.
Front driveshaft slip is siezed. Driveshaft cant telescope. Im pretty sure the Ujoints are shot too, but cant take driveshaft out to confirm. Will likely have to destroy the driveshaft to get it out.
Bearings in xfer case are in need of replacement. Play on rear output shaft.
Muffler, leaks. This is a normal wear item. Not fords fault.
Rockers etc. They were "repaired" while still under warranty for surface rust. Job was not well done. Now I have to completely replace the rockers. Known issue. Water leaks in the rear 3rd brakelight and takes out the rockers from the inside. Ford didnt seal the light correct.
Drivers seat needs replacement. Leather wore through and tore. Leather was not tough enough.
At least one COP is shot.
Thats about it off the top of my head lol.
And yes it gets lousy mileage on top of all that;)
I rest my case on Ford vs Toyota!
   / 2013 Tundra vs 2013 Ford #137
I have now learned Toyota makes a far superior truck than Ford other than the very minor issue of the frame twisting and letting the truck bed dent the truck cab. I guess it does have a frame like a 3/4 ton doesn't it.
Any other thread the guys that live up north like to brag how bad the salt eats evertthing up but since we are talking about a Ford it is "poor engineering".
I know several people that have 97-04 F150's and they have been very reliable. Some even tow a lot with them or use them on their orchard.
   / 2013 Tundra vs 2013 Ford #138
Toyota replaced a lot of frames and issued many checks for rusting frames. Hard to argue with that.
As far as Ford frames go, at least around here, they seem to rust worse and quicker than Ram or GM trucks do. The same goes for their exhausts and rear suspensions.
Not sure that frame rigidity and strength should be thought of as one in the same. Obviously a cab and bed hitting each other is not ideal. Frames are built to a certain Hz that goes along with lots of other design details of the vehicle, like wheel size or wheelbase.
Ford frames are typically huge looking and have more cross sectional area than the others. They use lower tensile strength steel so they have to use more of it. Just a different approach to accomplish the same result.
   / 2013 Tundra vs 2013 Ford #139
Dana pays $25 million to Toyota to settle Rusty Tacoma Frame claim
   / 2013 Tundra vs 2013 Ford #140
Yeah and Fords are notorious for catching fire. What's your point? (0:
Personally I like my Dodge powered by a 5.9L Cummins Diesel.
2019 Ford Explorer (A55788)
2019 Ford Explorer...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
Yellow Posts (A55973)
2008 VIKING TRAILER 40+5 LOADER TRAILER (A58214)
2008 VIKING...
