2030 new clutch problems
/ 2030 new clutch problems #1
psj12
Platinum Member
Short OK
KIOTI 551
I was just asked by an elderly neighbor to look at his 1987 JD 2030 that his son just put a clutch assembly in. I did not take part in the installation so I can't answer specifics about what was done or not done. The old gentleman says the entire pressure plate and throw out bearing assembly was replaced. I did find the old one nearby and the plate between the fly wheel and pressure plate was missing all it's friction material on one side and was an entire assembly. The son is not available for comment.
Here's the problem. The tractor range selector on the left that has a Park position will not go into gear. It just grinds so I'm pretty sure the clutch is not releasing. I pulled the gear selector (right side) back out of the park position and not I cannot move it at all even to return it to it's former position.
I looked at the clutch pedal free play and it was fine. I removed the inspection covers on the left side of the bell housing and had the farmer's daughter depress the clutch pedal. It appears to be working the clutch fingers fine and completely disengaging the fingers when released. The engine runs and is not bound up. What could the problem be? I need help. I hope I don't have to resplit the tractor.
It appears upon second examination that the clutch is a single stage type. Does anyone have the proceedure for the external adjustment of the clutch fingers?
2021 CATERPILLAR 308CR EXCAVATOR (A65056)
2021 CATERPILLAR...
PORTA POTTY (A68842)
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2011 FORD F-250 SUPER DUTY (INOPERABLE) (A67714)
2011 FORD F-250...
