2305 engine needs to be rebuilt
   / 2305 engine needs to be rebuilt #72
I'm gonna try and list it...but I've heard this forum frowns on listing other forums and treats the name like a curse word...like this****. It is deeretalkdotcom.
edit...well,I'll be...it came thru without the censorship.....now I'll probably be banned.
Thanks. I am a member there too. Love tractor content.
   / 2305 engine needs to be rebuilt #73
classic said:
+When they're done rebuilding have them run it on the dyno for an hour. That'll break it in and make the rings seat.
Dealers here do this on a rebuild. Trouble is dealers do not have dyno's this small.
Dealer just call, if everything goes according to plan, it should be ready by tomorrow. :D They also change the tranny fan which was the reason I brought it down there in the first place, and they fix a slow leak in a front tire. They had it on the dyno and everything seems to be running as it should with no leaks to be seen. I will be picking it up more than likely on Wednesday. :cool2:
   / 2305 engine needs to be rebuilt #76
You'll have to take a picture of that 2305 on the dyno. Hard to imagine a dealer having one that small. Have them give you a printout so you know what your pto HP is.
I'll try. I think I saw it the last time I was there. If it is what I think it is, it connects to the rear pto.
   / 2305 engine needs to be rebuilt #78
grsthegreat said:
well i see truckers idle their righ for hours while pulled into rest stops while they sleep.....why is this ok for them??
I would imagine most of the truckers that are spending hours in a rest stop are running at 1000 rpm (idle is probably 600 rpm). If they are just stopping for 10 minutes then they won't set the rpm's up but just let it idle.
   / 2305 engine needs to be rebuilt #79
Yes that is it. The load on them should be adjustable, correct?
Any shop worth their name will dyno anything that has had fuel work done on them.
   / 2305 engine needs to be rebuilt #80
A lot of truckers will shut the truck down when they sleep, and rin the Webasto to keep everything warm.
UNUSED FUTURE ELECTRIC BICYCLE (A57193)
UNUSED FUTURE...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
2020 DRAGON ESP...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
