2305 John Deere hydraulics
   / 2305 John Deere hydraulics #1
Boznaros
Paola Kansas
John Deere 2305
I have a 2305 John Deere with a loader and belly mower. I dont have any auxiliary hydraulic. My issue is after the tractor has ran a while the loader slows down and I can’t get the mower deck to raise. Any suggestion?
   / 2305 John Deere hydraulics #2
How many hours do you have on this tractor? First thought with the little bit of information here is that the hydraulic pump is worn out. When the oil warms up and the oil becomes more viscous, the pump pushes less oil through the system lowering the pressures.
If I remember correctly it is a 2010 so not a lot of hours for this tractor
   / 2305 John Deere hydraulics #5
Not many hours for pump failure. The only way to determine what is going on is to put a pressure gauge on the hydraulics.
When the oil is cold, can you pickup the front of the tractor with the loader?
   / 2305 John Deere hydraulics #6
Following. Curious to hear outcome.
Yes even when it is warm it will pick up the front it is just slow doing so
   / 2305 John Deere hydraulics #8
Very interesting. What you say would indicate good pressure, just poor flow?
   / 2305 John Deere hydraulics #9
Have you checked hydraulic fluid level? Fluid condition, is it milky in color? Does this machine have a screen for the fluid? Just some initial things to go over.
   / 2305 John Deere hydraulics #10
Also, do you have to rev the engine to do this when the oil is warm vs idle to mid rpm when it is cold?
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
JOHN DEERE 450K LGP CRAWLER DOZER (A52707)
JOHN DEERE 450K...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
44029 (A51692)
44029 (A51692)
