2305 Parts
/ 2305 Parts #1
WV 2305
Anyone know of any salvage yards that may have 2305 parts? Front axle was broke out from under the tractor so the center section and pinion carrier is what is needed. About $1000 new from the dealer.
Thanks,
WV 2305
/ 2305 Parts #2
I just typed "Tractor Salvage Yard" into Google.com and found more than I expect to find. I guessed your location to be West Virginia from your screen name so when I added West Virginia to the search terms I found some more results.
Do your own Google search or try this as a starting point?
http://www.tractorhouse.com/Dealers/BusinessTypeSearch.aspx?FeaturedType=part
Good luck!
-Bill
/ 2305 Parts #3
What the heck happened to your machine to cause the front axle to break?
Being that the 2305 is a fairly new machine I suspect finding a used one will not be easy...But since the 2305 is basically the same machine as the older 2210 they may use the same axle (you can verify that in JD Parts), If so then that will broaden the possibility of finding one.
