Chains 2305 rear chains
/ 2305 rear chains #1
toadman40
will the TY25324 rear chains from the dealer fit an r4 rear tire. call john dealer and they said the chains part number will not work for the r4 tires. any help
/ 2305 rear chains #2
these would fit i would imagine, but you
may need to swap tires side to side to gain
clearance for the chains.
TY15958 Tire Chains (Pair) for 26x12-12 Tires
/ 2305 rear chains #3
TY15958 is what I have been using on my R4's. I have the independant lift option. The
hose that is behind the left tire had to move a little.
/ 2305 rear chains #4
I have done this. I have a Backhoe so I needed spacers to clear the mounting frame. Once the spacers were added the chains fit nicely.
/ 2305 rear chains #5
I have backhoe and bought JD wheel spacers on ebay for about 1/2 the price of JD wanted.
Not sure which chains JD was talking to you about but the ones for a 425 ,suppose to be there heavy duty chain was more than 3/4 of the way worn out at the end of 3 or 4 winters.
So when I bought my 2210 I made my chains from widest vbar tire chairs for 1/2 pickup. 15 or 16" tires
took one end of hook off side rail ,plus hook off the cross link. then clamped the vbars together and then welded top and bottom of links..
I have used them going on 6 or 7 winters no links broken and holding up very well. Doing 8-12 driveways and church parking lot for all that time and a distance of close to 1/2 miles sometimes 2 times a day...
