2320, 2620, or 2920
   / 2320, 2620, or 2920 #21
RSKY;
I purchased the 2920 because of snowblowing contracts in the winter (eastern Ontario) with the 51" industrial blower. 21 pto hp and have never bogged the engine down! Don't even run at rated speed and plenty of power. If you can afford the extra hp do it! You can always throttle back if not needed...and for fuel efficiency I have cleared up to 50 residential drive in a day and used up to as little as $13.00 of diesel fuel. Very fuel efficient!
Great machine you will not be dissapointed.
   / 2320, 2620, or 2920 #22
I used to run a 60" snowblower with a B7510 that only has 16hp at the PTO. Never had any problems. It probably went a bit slower then the larger hp engine would have but it was well within the capability of the machine. Now I run the same snowblower with a 22 PTO hp machine and there is a slightly noticeable difference.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
