2520 questions
/ 2520 questions #1
tmshort
Bronze Member
Indiana
All-
About to pull the trigger on a 2520 with 62" MMM, FEL, ballast box, and front blade for snow (brother talked me out of a blower).
Just wondering what add ons you all would recommend or what other things I might want the dealer to install before delivery. We have 10 acres, 1/2 woods 1/2 grass. Paved driveway ~400' long.
It seems like I read about some additional hydraulic options, etc that might be useful but I cannot recall what they were or if they apply to the 2520.
Thanks in advance...
/ 2520 questions #2
I've got about 350' of driveway to keep plowed all winter. And 3 parking areas. And 3-4 neighbors and the cluster mail-box a mile and a half down the road...
Nonetheless, I've found that over the course of the winter - I run out of space to "push" the snow off to the side any longer. I have to use the loader bucket to "move" the snow someplace away from the road and buildings.
That's one of the biggest reason's I've stayed with a loader bucket and a rear blade for all my snow chores.
A blower would be a quicker and often easier way to handle the snow buildup - but, it won't work for "beans" in the cramped and often multi-building's or other structures close to the tractor situations that I have to plow in.
If it were my dollars - I swap the front blade for a rear blade. And be able to move snow in reverse as well as forward.
That said, get all the lights - front and back - you can.
AKfish
/ 2520 questions #3
I agree. I would like to have a blower, but using one every couple years (around here) really doesnt justify the $$ of one. I can use the loader/rear blade year round. And the rear blade just pops on in seconds (thanks to the quick hitch).
Engine block heater would be another good buy. And if your winters are cold and parking in a unheated shed, trans heater might be another good idea. I only have a block heater and use it several times every year.
/ 2520 questions #4
I have the warning light brush guards and forward lighting kit. I actually have one of the lights facing rearward so I get light to see rear implements.
I also have the hydraulic diverter valve to allow me to leave the MMM independent lift hooked up and switch between bucket curl and mower lift with the valve.
If you do go with a rear blade, go with an iMatch hitch to make it easier to connect and disconnect the blade.
/ 2520 questions #5
I went with the front blade also for snow removal..I just hate looking backwards all the time to remove snow with the rear blade..
/ 2520 questions #6
All-
If you are getting the front blade then you will atleast have the front hitch for the blower if you ever decide to get one.
Work light are very nice especially in the winter when it is dark out and you have to move snow. Most front implements block the headlights making them almost useless. The brushguards and front and rear worklights are a very nice option and I think they will come in handy for you.
/ 2520 questions #7
All-
As far as the snow blower/blade dilemma. My first question is do you get a lot of snow where your located? If you do I would opt for a snow blower. But if you live somewhere that gets 30" of snow a season I would get the blade.
Everyone is going to give there opinions but you have to take into consideration there location. I myself need a snow blower as it's nothing for me to receive 30 inches of snow overnight. After you get that 2 days in a row you quickly run out of room to put the white stuff. Am I making any sense.. :D :confused2:
FEL question? What size bucket did you opt for. I would make sure you got a bucket width at least as wide as your tractor width. I upgraded to the 61" bucket as I didn't want to run over the dirt I was missing with the narrower bucket.
As far as the Independent lift, I went with it as I didn't like that long steel arm hanging down when the tractor was setting and the 3pt hitch was all the way lowered. Also if I decided someday to get a tiller and I didn't feel like taking the mower off that day. I could just lock it all the way up and I wasn't lowering the mower deck into the dirt when lowering the tiller. I know they make a chain kit for holding the deck up but I didn't want to crawl under the tractor eveytime I want to lock the deck all the way in the up position. With the independent lift you can do that without leaving your seat..
Again all just my opinion :2cents: and you know what they say about opinions. :D
__________________
/ 2520 questions #8
I always liked the extra front lights on the SX3100..I bet that hood would bolt right on a 2520..
/ 2520 questions #9
They probably all have them now, but I would caution you to MAKE ABSOLUTELY SURE that your machine has the "new-style" three-point draft arms when it is delivered. This will prevent many headaches with tire-rubbing issues and they are $300 apiece if you have buy them later. There are numerous threads on here showing the difference, but basically, there is an extra offset in the implement end of the arm.
If you will be mowing on hills, you may wish to consider wheel weights or filled tires for better traction.
Also, if you deal with leaves (you mentioned property is half trees) there is a mulching kit available for the 62D.
I personally, would also make sure the dealer provides you with BOTH of the PTO shaft guards. They are little plastic beer-can sized covers that go over the PTO stubs when not in use (to keep them from getting dirty/rusty). My dealer only gave me one, and they are $25 apiece if you have to buy them later.
I agree wholeheartedly with the comment for extra lights, you will need them for snow duty.
I have a front blower, but if I were doing it again, I would just have the loader, rear blade and a rear blower (OK, maybe the front blade too). I hate having to remove my loader to use the front blade/blower.
Best of luck with your machine, I believe you will be very happy with it.
/ 2520 questions #10
I'd get one rear remote, sooner or later your going to need it.
/ 2520 questions #11
Welcome to TBN tmshort!!:)
As Runner stated,make sure you are getting the new style lower 3pt arms.
Lights,lights,lights
Do you have winters? If so,and your tractor is stored in a unheated building, definitely opt for the block heater. It makes a world of difference.
I would opt for the 61" heavy duty bucket also.
If you are going to leave the mower on and do other chores,then I would go for the independent lift,but if you're one to only have attached for what is needed for the task at hand,put that extra cost towards something else,like a cutting edge,or a toothbar,boxblade, yard rake,or even a power beyond kit.
Maybe get the dealer to put some hooks on your bucket.
Whatever you decide,I wish you good luck with your decisions.:thumbsup:
You will love your 2520 too.:D
/ 2520 questions #12
also make sure they top off the Hydrolic fluid after installing the loader..My dealer did not..We added almost a gallon to it..
/ 2520 questions
Thanks for all the input and advice..
I am in central Indiana, so snow is a small factor, but not usually to the point where it builds up in significant piles.
Any thoughts on the 62" MMM vs the 72" rear finish mower (GM2072R I think)? The property is pretty open and mostly flat (rolling hills but not steep at all). Can the 2520 really handle the 72" (looks like the PTO hp is right at the bottom of the range).
It is a bit hard to get a grasp of all the different options and combinations.
Any recommendations for a good PTO powered chipper/shredder for the 2520? How about a 3pt mounted tank with PTO pump (not sprayer, but something to use for watering trees, etc - I use one of the spike root watering things).
Thanks in advance for the input ... maybe I should separate some of these into different threads...
/ 2520 questions #14
My 2520 handles a Frontier GM1072R 72 inch RFM with no problems. It is a little bit heavy, at 675 lbs, so I like having the loader on for counter weight when I raise the mower for transport. If I don't have the loader on, I use 7 of the 42 lb JD weights on the front bracket.
I have both the 62D and the GM1072R RFM, and I think the RFM delivers a nicer cut. It is also easier to drop off the RFM when I want to use some other attachment where a mower would be in the way.
