y
2538 Oil leak not an oil leak
   / 2538 Oil leak not an oil leak #1
millsan1
Riegelsville, PA
Mahindra 2538 Cab, Volvo ECR40D Excavator
My 2538 was puking a bit of oil when sitting or running or basically existing.
I had a bunch of chores to do with it, so I couldn't troubleshoot. So I just kept feeding a bit of oil in every couple hours.
When I finally had time to trace down the leak, it was not a leak, really. The oil filter had semi unspun and was weeping around the oring. I have never had a filter back off like this on any vehicle, ever. Weird. Tightened it back up and all is well.
   / 2538 Oil leak not an oil leak #2
Make sure if you are the one changing the oil filter, always put some oil on that rubber gasket then snug it up.
2377 (A60432)
2377 (A60432)
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2011 JLG E400AJP BOOM LIFT (A60429)
2011 JLG E400AJP...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
