2565 EGR ISSUE
   / 2565 EGR ISSUE #11
Once you get the EGR clean and make sure you are running it hot enough, you should be good to go. I'd either block the radiator some or put a cold front on her. That big extra aggressive multi-blade thing they call a radiator fan it probably great for a guy working his tractor when it is 90 degrees out, but too much of a heatsink to allow it to run at the proper temp in the winter. And the cab has a big heater core with two big squirrel cage blowers sucking heat. ESPECIALLY when it's down around zero like it is now. I have never had a problem idling my tractor for periods. But if you want to work the motor any you want the RPM's up. You can even putt around at 1200-1500 without a load. But any motor load needs the RPM up...
   / 2565 EGR ISSUE
Thanks Jerry,
I'm kind of thinking that if that is the worst fix I ever have to do to that tractor I'll be a very lucky man. The radiator cover seem to make the tractor warm up a lot faster and throttle response is just what it's supposed to be again.
   / 2565 EGR ISSUE #13
:) :) :) [ Life is GOOD... !!!! ]
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
200 Gallon Tank (A57148)
200 Gallon Tank...
MACK GR64F DUMP TRUCK (A59823)
MACK GR64F DUMP...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
24017 (A56859)
24017 (A56859)
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
