Oil & Fuel 2615 transmission oil
   / 2615 transmission oil #1
buck12
Veteran Member
Mississippi
Kubota 5460HSTC
I am getting ready to service my 2615 gear for the first time. The manual seems a little confusing on several points including which fluid to use in the transmission. The lubrication table shows that for transmission/front diff. to use Citgo-Transgard Tractor Hydraulic Fluids, Exxon-Torque Fluid 56, etc.. The manual does not specify if this for a HST or gear drive transmission. Does this mean that HST and gear tractors use the same fluid? For those with 15 series gear drive what are you using?
   / 2615 transmission oil #3
I'm using Chevron for the transmission/front diff. and then Amsoil oil for the engine.
As always the information/advice provided by the members of this site is appreciated.
   / 2615 transmission oil #5
I used NAPA heavy duty hydraulic fluid in the transmission/front diff and Chevron Delo 400 in the engine.
Is that in the yellow bucket? I was at the local NAPA store yesterday for something else and noticed it was $26 per 5 gal bucket.
   / 2615 transmission oil #7
No. I have it as "NAPA Premium Universal Tractor & Transmission Fluid". Part NHF 85405. 5 Gals @ $55.83. They have changed the website and the 'refinements' just made searching much harder. The attached picture is the oil used. It also comes in gallon jugs. I think I used close to 7 gallons between the hydraulic's and front diff with some left over. Can says "Meets JD J20C, Quatrol Case IH, Hytran Plus MF Permatran III Specs".
Regards
   / 2615 transmission oil #8
7520 Engine Oil Change. Has anybody figured out how to fill this model up with new oil without it taking hours. This is a terrible design. It only takes a thimble at a time without running over?
   / 2615 transmission oil #9
I do not have a problem. I use a funnel and pour away. You have to drain the old oil out first.:confused3:
Utility Trailer (A52377)
Utility Trailer...
Sewer Tank (A52377)
Sewer Tank (A52377)
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
CATERPILLAR D6T XL CRAWLER DOZER (A52705)
CATERPILLAR D6T XL...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
