2810HST will not start
   / 2810HST will not start #21
I'm a little confused as well. When you turn on the key do you get any lights to come on at the dash? Have you checked the fuses yet? I also have a 2810 older style with gear shift in the center. According to my manual if one of the 3 main fuses blow the entire electrical system is shut down.
   / 2810HST will not start #22
I had a problem with my 2600 Ford. Checked everything and found to be ok, Tried crossing the starter and it cranked. So that left two things. Either the key switch or wire. Checked the wire and no reading between switch and starter , Ran new wire from switch to starter and problem solved. I recently traded the Ford 2600 for a Montana 4320.
   / 2810HST will not start #23
Just courious, what you found, or if you had a chance to investigate yet?
   / 2810HST will not start #24
The original poster has not replied in a month. Wonder if he ever got it fixed.
2014 Ford Fusion Passenger Car, 2.5L Engine - Only 90,875 Miles (A56438)
2014 Ford Fusion...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
44052 (A55852)
44052 (A55852)
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
