2nd choice of tractor
   / 2nd choice of tractor #31
   / 2nd choice of tractor #32
I don't remember, but it is small. It is 25 hp, and has a loader. I have spent about equal time on a similar sized same hp Kubota. The Kubota is a lot better.
Maybe an older model. The CK25 is way more tractor than an equivalently powered B7500/7510 and has considerably more weight and loader capacity. My CK20 could easily outlift a B7500. I've never operated one of the pre CK/DK Kioti models but I'd probably choose a Kubota B series over the old Kioti LB series.
   / 2nd choice of tractor #33
I woulda got a deere, just cuz. The Kubotas and mahindras just didnt feel as good as the Dk! And if it aint one of those, then a green one.
   / 2nd choice of tractor #34
That is incorrect. A B2650 weighs almost exactly the same as the ck25. The ck25 is rated to lift 1,000 pounds, and the B2650 is rated to lift 1,100 pounds.
   / 2nd choice of tractor #35
I'm not up to date on the new Kubotas and was comparing the CK25 (currently sold as CK27 with a boost of HP but I believe otherwise identical engine etc) to the Kubota B7500 series which I believe has been superseded by the B2650. CK25/27 lift 1155lbs to full height at pivot pins. Weight is over 3100lbs in ROPS model. Clearly bigger than the Kubota B2650 ROPS model which weighs only 1786lbs in the literature I read on line. I was comparing sub 30hp CUT versions of Kioti and Kubota.
The Kioti CK2510 weighs 2260lbs is rated at 1092lbs lift so pretty close to the B2650 in both weight and lift capacity.
Enmark Z Spray (A53316)
Enmark Z Spray...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
