2WD GMC 2500HD
   / 2WD GMC 2500HD #71
We also had a 1993 GMC G20 short wheelbase van conversion with a V6 and wide tires. That was rascally on the snow, but still got around OK with some weight in the rear. A full tank of gas helps a lot as well.
   / 2WD GMC 2500HD #73
If the weight is so good on a 2wd, what does weight do on a 4wd truck?
   / 2WD GMC 2500HD #74
My F450 is a dually, stick shift, open diff, 2wd, diesel. I haven't had it stuck. But I'm careful where I go with it. Nothing wet unless its wet pavement. I try to avoid driving it in snow (it does just fine) because I limit the salt exposure as much as possible. If anything I might try to upgrade to a limited slip diff if I have to open the rear end up, but otherwise I', happy with it.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Hook & Cable Strap (A59076)
Hook & Cable Strap...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
2001 B&G Low Boy Semi Trailer (A57148)
2001 B&G Low Boy...
Unused Post Pounder Attachment (A55272)
Unused Post...
Lincoln Electric Ranger 10000 AC/DC Welder Generator (A56857)
Lincoln Electric...
