2WD GMC 2500HD
   / 2WD GMC 2500HD #71
We also had a 1993 GMC G20 short wheelbase van conversion with a V6 and wide tires. That was rascally on the snow, but still got around OK with some weight in the rear. A full tank of gas helps a lot as well.
   / 2WD GMC 2500HD #73
If the weight is so good on a 2wd, what does weight do on a 4wd truck?
   / 2WD GMC 2500HD #74
My F450 is a dually, stick shift, open diff, 2wd, diesel. I haven't had it stuck. But I'm careful where I go with it. Nothing wet unless its wet pavement. I try to avoid driving it in snow (it does just fine) because I limit the salt exposure as much as possible. If anything I might try to upgrade to a limited slip diff if I have to open the rear end up, but otherwise I', happy with it.
12ft x 8ft Military Flat Bed (A57453)
12ft x 8ft...
2001 B&G Low Boy Semi Trailer (A57148)
2001 B&G Low Boy...
2007 John Deere 6215 (A57148)
2007 John Deere...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2012 CAT 316EL (A55272)
2012 CAT 316EL...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
