3 1/2 to 4" concrete hold skid steer?
   / 3 1/2 to 4" concrete hold skid steer? #1
MNBobcat
Platinum Member
Hi Guys,
I have a concrete slab that was poured mid august and it runs 3 1/2" to 4" thick. I'm wondering if that is thick enough to drive a bobcat 763 skid steer on without cracking the slab?
   / 3 1/2 to 4" concrete hold skid steer? #2
With thinner pours a lot depends on what's under it. Solid ground with a gravel underlayment? Solid ground with sand or with no underlayment? Fill dirt?
Gravel underlayment can actually increase strength because of increased thickness.
There's a LOT of difference in strength due to thickness.
Hopefully an expert will chime in with factual data.
It is solid ground with compacted sand. It was a really hard base.
   / 3 1/2 to 4" concrete hold skid steer? #4
In my opinion you'll be fine. Assuming you are just parking on the slab, not using it for a work area?
   / 3 1/2 to 4" concrete hold skid steer? #5
Will 3 1/2 to 4" concrete hold skid steer?
My V417 will hold 3 1/2 to 4" concrete. :D
   / 3 1/2 to 4" concrete hold skid steer? #6
I've driving a Bobcat S750 skid steer around on the slab in my pole barn. The slab is 3.5-4" concrete poured over well settled class 5 gravel base with rebar reinforcement, 2" dense foam insulation below and pex pipe for in-floor heating. I've also driven large 5th wheel campers (32-40') and a 32' motorhome across the slab without ill effects.
Rob
   / 3 1/2 to 4" concrete hold skid steer? #7
My full sized loader backhoe drove over my 3 1/2 inch driveway dozens of times without cracking it. It weighs 14,000 pounds. I had to drive across it to get into my backyard. Of course, I then had to have a full dump truck go across it to get to where I'm building my swimming pool, and that cracked it pretty good. No worries since I plan on removing all of the concrete to build my garage.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2024 DIGMASTER MINI EXCAVATOR (A58214)
2024 DIGMASTER...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
204158 (A57193)
204158 (A57193)
2019 Ford F-550 (A55973)
2019 Ford F-550...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
