3 Cylinder Life
   / 3 Cylinder Life #1
holstein05
Missouri
Quick question. Coming off of a farm I am used to the big machines with 3000-4000 hrs on a tractor not being all that unusual before an overhaul. Now however, I am looking at some 3 cylinder tractors (I'm no longer on the farm) for small jobs I have, and was just curious, what kind of Engine life do these smaller engines have?
Thanks
Holstein05
   / 3 Cylinder Life #2
It will relate more to usage than # of cylinders. Utility tractors don't see near the heavily loaded hrs a field tractor does and normally see longer overhaul interval. 3k hrs for a is a might short for a properly maintained field tractor.
   / 3 Cylinder Life #3
I've got a '67 Massey 150 with Perkins 3 cylinder diesel, showing 2900 hours and still in the prime of it's life. Not at all uncommon for these engines to see 10,000 hours without overhaul.
   / 3 Cylinder Life #4
That's what I've heard also, 10,000 hour machines. /forums/images/graemlins/grin.gif
   / 3 Cylinder Life
10,000 hours? Wow, I like the sound of that!
Thanks guys.
What about the pros and cons of 4 cyl vs 3 cyl?
   / 3 Cylinder Life #6
Typically a 4 cylinder will run smoother BUT have less torque than an equally sized 3 cylinder.
KO
   / 3 Cylinder Life #7
</font><font color="blue" class="small">( am used to the big machines with 3000-4000 hrs on a tractor not being all that unusual before an overhaul )</font>
My ford 5000 is past that and runs good. I think you need to up that number to around 4-5K for harsh use, and 10000 for normal use.
I've even got gassers from the 50's and that era that made 4-5k and still have enough compression and oil pressure to do hobby farm work...
Soundguy
   / 3 Cylinder Life #8
I'll agree with everyone that the lack of heavy use or frequent abuse will add to life, but do think there are other factors:
1. Many of these machines are much higher RPMs than AG or commercial.
2. Many air-cooled engines run hotter than the oil or water cooled ones.
3. I have no idea of the target life these are designed for, but I'm not convinced it's the same as AG or commercial engines.
Anyway, I don't think you have a thing to worry about, but neither am I quite betting on 10K hours [in consumer targeted machines] until a few people have the clocks to prove it. /forums/images/graemlins/crazy.gif
   / 3 Cylinder Life #9
</font><font color="blue" class="small">( I'll agree with everyone that the lack of heavy use or frequent abuse will add to life, but do think there are other factors:
Anyway, I don't think you have a thing to worry about, but neither am I quite betting on 10K hours [in consumer targeted machines] until a few people have the clocks to prove it. /forums/images/graemlins/crazy.gif )</font>
Keep in mind that several tractors from the 1960's, 70's 80's and on into the 90's were BOTH "AG tractors AND 3-cylinders.
Ford 3000/3600/ect.
Massey 35/135/130/135/240/245/250/50/150
Deere used a few 3 cylinders, not sure of all the model #'s.
Point is, some of these tractors have spent 10,000 hours on farms as "chore tractors" and a few were even the #1 tractor on smaller farms. Come to KEntucky and see how many Ford and Massey utility tractors spent a lifetime on our tobacco farms.
They didn't get babied.
If I'm following your lead, you might be getting specific about 3-cylinders in TODAYS compacts, as opposed to 3-cylinders in general. Some of us were talking about 3 cylinders in general.
   / 3 Cylinder Life #10
Yeah, I know my points wander from the thread title, but thought I was going the same direction as everyone else! /forums/images/graemlins/crazy.gif
Anyway, what I'm saying is that 1,2,3 or many more cylinders isn't so much the issue as differences both in usage and design between AG & commericial machines [regarless of age] and the new ones targeted for the "consumer" market today.
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
SKIDPRO  SKID STEER GRAPPLE (A52472)
SKIDPRO SKID...
2017 Ford Expedition EL Multipurpose Vehicle (MPV) (A51694)
2017 Ford...
