3 cylinder vs 4 cylinder
   / 3 cylinder vs 4 cylinder #61
Could use the same discussion about 4 cylinder vs. 5 cylinder cars. Lots of smooth 5 cylinder ones out there.
By same token, arguments could be made about going down from 3 to 2 cylinders, e.g. like the BX 1500. Don't think it was particularly different in vibration than any other.
Re fuel consumption: gas engines with carbs will use 50% more fuel than non turbo diesel engines. We engineers had both kinds of vehicles back in the 80s. Our (mostly) cars with gas engines with carbs had 30 ton-mpg average. Average on our diesels was 45 ton-mpg. This is the mpg that a 1 ton vehicle would get. Could easily prorate by vehicle weight, except it didn't work for a diesel big Ford pickup. It used less fuel by weight.
Prorate tractor fuel usage by hp.
Ralph
   / 3 cylinder vs 4 cylinder #62
I know most if not all of the 30 - 40 HP compacts either have a 3 or 4 cylinder. Wouldn't the 4 cylinder be a smoother engine by default? If you had a choice between a 3 or 4 cylinder, which would you choose?
[video]https://en.wikipedia.org/wiki/Engine_balance[/video]
Engine vibration is dependent on much more than the number of cylinders. Cylinder orientation, crankshaft throw alignment and any other rotating component of the engine is involved.
   / 3 cylinder vs 4 cylinder #63
You can add crankshaft balancing counterweights to that.
I drive a Mitsubishi 3 cylinder tractor and as far as can say I never have noticed even the simplest undesirable vibration.
Now I once was near a 2 cylinder Kubota compact tractor and man did that thing shake rattle and roll.
   / 3 cylinder vs 4 cylinder #64
My Steiner 430 with the little 3 cyl Kubota is a rough little engine, especially at IDLE. The little 4 cyl Kubota Engine in my little Kubota Wheel Loader is also a bit rough at Idle. I bet, but I don't know, that a Kubota 5 cyl is as smooth as silk at Idle. Might even make a sweet generator running at 1200.
16ft Canoe (A56859)
16ft Canoe (A56859)
2015 GENIE S-45 TELESCOPIC BOOM LIFT (A52709)
2015 GENIE S-45...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2016 24' Iron King Flatbed Trailer (A57148)
2016 24' Iron King...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
Corn Grinder (A57454)
