3 hrs on new machine, go mow 3 acres?
   / 3 hrs on new machine, go mow 3 acres?
madpogue said:
If the inner and the outer shafts twisted at the same time/rate, they _might_ still telescope, no? Easy enough to find out. Just make sure the telescoping part is "good-n-greeeazy". _Might_ work until you can replace it, anyway.
Actually, you need a "worse" shear pin; well, a weaker one, anyway. Grade 2 bolt, right?
Hmm, we just took delivery on our JD 790. Half an hour on the clock on delivery. A few tenths just putzin' around getting used to it, but then we put 'er right to work (5' King Kutter, 20 acres). Dealer didn't recommend "babying" it at all. I was slowing the throttle here and there, just because I was getting used to it. The only "break-in" is an oil/filter change at 100 hours.
No shear pin. Inner is solid bar, twisted the outer only. It's been working, but I bought a replacement today with a radial clutch of some sort. No room for the slip clutch with disc, I'll see how this works.
I ended up mowing about 6 acres, twisting the pto shaft doing so. I think I'm past babying it at this point.
   / 3 hrs on new machine, go mow 3 acres? #22
Montejw:
If you purchased a PTO driveline with a radial pin slip clutch you probably do not need a disc slip clutch in the drive line. I have one on my tiller and it will slip. Do not over grease/lube it though. It appears that by over greasing it "over pressures" the slip ring collar internal release mechanisms making it difficult to remove. Jay
jbrumberg said:
Montejw:
I hadn't thought of getting both clutches. I didn't know about the radial pin slip clutch until today. Now the only thing I know about it is it takes up less space than the disc slip clutch.
   / 3 hrs on new machine, go mow 3 acres? #24
montejw:
They do take up less space and they appear to work sort of like a rachet. Do not over grease these units. Last year I could not get mine to release due to the pressure the grease was putting on the slip collar release band. I finally had to pull the slip clutch off my tractor's rear PTO stub with my 4X4 pickup truck. I did not have this problem this year as by the clutch's slipping during operation it released much of the grease pressure. It came right off :). Jay
jbrumberg said:
montejw:
I'll have to find a manual or drawing for this thing so I can see how it works. Thanks for the heads up.
JerryG said:
Deere has a pretty good description of when and how to lube your new clutch.
Pick-up Slip Clutch Won't Slip or Slips Above Specified Torque
Thanks, that explains how to lube it. I still need to find an exploded drawing showing the inards. I started taking stuff apart at a young age, made the parents mad a time or two when the stuff didn't go back together again. Now I look for drawings and manuals.
   / 3 hrs on new machine, go mow 3 acres? #28
JerryG:
Thanks for information. I wish I had this information before personal experience taught me. Jay
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Bell B30E (A50123)
Bell B30E (A50123)
Yanmar YM226 2wd tractor (A53473)
Yanmar YM226 2wd...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
