3 Point Attachment - Max angle?
/ 3 Point Attachment - Max angle? #1
buyerjohn
Berkshires, MA
DK45s with cab
I want to cut some swales through soft dirt using my landscape rake. I cranked the handle on the right side lift rod that lowers the right lift rod and in turn pushes the right side lower link down - this makes the rake slope downwards from left to right when facing the rear of the tractor.
However, this angle isn't very steep...is there any other way to increase the downward slope of the rake from left to right without installing a hydraulic tilt? I've seen some crazy angles in pics posted here but I think they all use hydraulics.
thanks.
/ 3 Point Attachment - Max angle? #2
A simple fix is if either vertical link has more than one place for the pin so you can change its length. Next would be a second adjustable link. However, if you can afford a hydraulic tilt you will gain much more functionality. If you put your adjustable link opposite the hydraulic one you can make large tilts in either direction quick and easy. Add the top control and get really happy.
Steve
/ 3 Point Attachment - Max angle? #3
Steve
CCM Machinery makes nice kits for Top n' Tilt. Do you have the hydraulic ports available to run two rear cylinders??
-Jer.
/ 3 Point Attachment - Max angle? #4
Maybe try some gauge wheels?
/ 3 Point Attachment - Max angle? #5
buyerjohn, did you try running your adjustment the other way? Often they will adjust one way more than the other. Then and don't miss this, rotate the rake where the lower end is the leading edge. Be sure it clears your tractor tire. That will make more difference than you think. Not sure how well this works on a rake (yes I have moved dirt with a rake but it is not smooth) but with a blade the dirt will roll up the hill for you. Ever notice a road plow? Same thing. At same time you don't want to over load the leading edge this way as the majority of the load is on that point.
/ 3 Point Attachment - Max angle? #6
You can cut large ditches with a angled straight blade. Just lower one side of 3ph raise the other, and put the blade on an angle to tractor so dirt will roll out of the way.
First pass wont be much, second may not be either. But the more you cut the more angle the tractor will be on. Put a set of tractor wheels in ditch, and the other on the pile of dirt you removed from ditch.
This may not make sense in reading, but try it. Each pass will make the ditch angle deeper and steeper since the angle compounds.
I did max out the angle with the crank handle...but rotating the rake to the rear tire made a big difference and then, as KT suggested, each pass makes the cut better...thanks guys...
/ 3 Point Attachment - Max angle? #8
Your probably already know this but speed also affects this. A little speed will cause the dirt to roll better with a blade, not sure with a rake. Glad you got the results to please you. 8934 made a great point on placement of wheel.
BUNDLE OF (1) TOPLINK & (2) LIFT ARMS (A62130)
BUNDLE OF (1)...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
UNUSED ATS CMR1280 ELEC.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2005 Ford F-250 Utility Truck, VIN # 1FDSF20P95EA36131 (A61165)
2005 Ford F-250...
