3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Yeah, I think a PTO pump is something like four or five hundred bucks by itself?
Jump on it! I paid a lot more for probably the same Kubota hoe. If it's been on his JD 750 (a small tractor) for ten years without breaking it then it shouldn't hurt your larger Deere.RollTideRam said:Kubota 3pt hoe that he has used on his Deere 750. ... I know he has had it for about 10 years. ... $900.
Soundguy said:You can take the sarcastic head burried in the sand route or not.. it's your choice. Fact of the matter is.. 3pt hoes can break tractors in half. I've seen it.. Many here have. It doesn't happen as soon as you bolt it on.. it's usually a slow process of stresses that fatigue and crack the metal that culminates in a break once the metal distress reaches a point that is overcome by the next big flexing stress the hoe puts on it.
Manufacturers don't make hoe subframes just to pad costs.. there is a reason for them.
Soundguy
john_bud said:Why aren't more tractors broken in half from 3pt mounted hoe's?
They aren't used enough. Most manuals for construction equipment list 500 hours (or so) as the time to inspect for structural cracks. Usually around 1500-3000 hours a hoe will start to show small cracks at the weakest areas. If left unchecked, they will grow until you are the proud owner of a schizophrenic tractor.
If you want a reality check, put an operator on your 3pt hoe tractor and stand behind it with a stationary level that matches up to the top of the tires and watch as a full bucket is swung with the boom/stick extended. There is a LOT of flexing going on. You see that and you won't wonder anymore!
jb
rural2 said:I do not recall asking for a reality check and why would I set up a level in order to watch someone else work my hoe when I can just sit in the seat myself. I am well aware there is movement, when it becomes excessive I re-set my stabilizers. Maybe we are talking two different things here???
I do not know anything about construction equipment manuals, however I have operated several full size hoes on occasion and I had, until a couple years ago, been around them on a daily basis. To attempt to compare a full size hoe to a CUT teaspoon is a gross mistake in my opinion. In thirty years I can count the number of non factory welds on booms, dippers and frames I have personally seen as less than ten, just not real common in my experience. Buckets are another matter entirely. Some of the hoes I am familiar with were fully depreciated, sloppy, nasty looking, wore out, hunks of junk w/tens of thousands of hours on them. 1500-3000 hours is just getting broke in with some of that stuff! So, in my experience you are mostly incorrect in that regard. I am aware of a couple problem prone makes and models, however they almost never made an appearance on a heavy commercial construction site, the few I recall that did show were usually brand new and didn't stick around all that long. The subcontractors doing the light excavation work were not stupid enough to buy or lease another one.
"won't wonder anymore" LOL! You really got me wondering now...
Enough of this, it is not relevant to the thread topic!
rural2 said:No need to be so hostile! Your concern regarding my "sarcastic" post is duly noted as is your limited range of my "choices".![]()
A much more effective response with me may have been to provide some relevant data supporting your preference for a sub frame attachment as opposed to 3ph attachment. Obviously my "personal" opinion and experience differs from yours. So maybe just a simple survey of some CUT dealers w/ratios to support your conclusions, or something.
Although I agree that a subframe attachement would be the better choice...
It is my current, personal opinion based on thirty years in heavy commercial construction and my more recent experience owning and operating the equipment listed in my sig. that you are making a mountain out of a mole hill. Until something/someone convinces me otherwise that is my current opinion right, wrong or otherwise, like it or not.
