Rara Avis
Veteran Member
hbaird said:I believe far, far, more hoe mounted tractors are damaged by being driven too fast over rough ground than by using the hoe. A hoe, or any other heavy object, cantilevered on either end of a tractor will put tremendous force on the bell housing of the tractor in motion. I suspect you can miss use a hoe and damage the tractor, but it would take something really special if the stabilizers are correctly in place. If anyone can show some vector diagrams defining the forces that can do any more damage than bouncing the front or rear end of the tractor off the ground I will admit my miss understanding of the problem. The rear wheels and the stabilizers provide four points of location for the hoe forces. If the operator isn't moving the forces don't go anywhere else on the tractor. On the other hand it only takes a small drop off or abrupt rise to get 50 to 100 G's. Even a small hoe can weigh 1000 LB or more, times the cantilever distance. It is easy to get enough force to break anything.
Harold
Actually a backhoe operates most effectively from the TRIPOD position...stabilizers and front bucket being the only points of contact with the ground...WHEELS are UP...at least thats the way the International Union of Operating Engineers teach backhoe operations...in fact if you don't put the front bucket down and operate with the front wheels in contact with the ground you will experience bounce during the operation of a backhoe...
