3 Point Fronthitch Kubota BX25
   / 3 Point Fronthitch Kubota BX25 #1
zunnie
Hello , dear People
I疥 a owner of a BX 25 in Holland and a like to have some pictures or and
drawings to make a 3 point fronthitch including drive shaft !!
I hoop some body can help me ,,thank you in advance !!
Regard Zunnie from Holland:thumbsup:
   / 3 Point Fronthitch Kubota BX25 #2
Welcome to TBN. :)
   / 3 Point Fronthitch Kubota BX25 #3
Hello & WELCOME to TBN!
I moved your thread to the Build-It Yourself Forum. :)
   / 3 Point Fronthitch Kubota BX25 #4
Zunnie,
Welcome aboard, you've come to the right place as there are some front 3 pt hitch conversions on here. I did one for a front mount blower on my Massey Ferguson 399 4wd. You can see the entire process here. The only problem I've encountered is throwing the rear drive chain under heavy load. I need to modify the rear drive sprockets/chain to eliminate any possible flexing of the pto shaft, much like the reverser unit that I mounted up front with flange bearings supporting the end of the shaft If I had mounted the reverser in back the way it was designed, I wouldn't have the problem, but I didn't want to take the reverser off in the summer and had plenty of room for it in front.
Hope this helps.
http://www.tractorbynet.com/forums/build-yourself/187397-max-snow-beast-finished.html
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
