3-point hitch lever on L2650 - how to adjust? Keeps falling.
   / 3-point hitch lever on L2650 - how to adjust? Keeps falling. #1
SouthernSky
Platinum Member
Deville, LA
2013 Kubota L3200DT
The lever to raise and lower my bushhog or box blade keeps drooping down/forward instead of staying in one position, thereby causing the implement to go lower than I want it to because of whatever weight is attached to the three point hitch.
How do I adjust the lever so I don't literally have to hold it? Is there an adjustment screw? Is it tied to the PTO turn handle under the seat?
Thanks in advance!
   / 3-point hitch lever on L2650 - how to adjust? Keeps falling. #2
I had the same issue with an L3400HST, but found out tightening the nut wasn't the issue. Instead, the lack of friction was due to a broken washer. If your L2650 is similar to my L3400, you can see my post Replacing Friction Plate Feed Back earlier and in the attached PDF file you will need to loosen part # 90, tighten 80 to your taste, and then tighten 90 back up.
Interesting. Mine doesn't quite look like the same design but it was worth a look for sure. Thanks for the reply!
I'm open to any suggestions.
Toro Mower (A50324)
Toro Mower (A50324)
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
377789 (A51573)
377789 (A51573)
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
