3 point hitch question
   / 3 point hitch question
Ill have to keep that in mid when ordering attachments. Do the mfg's offer a slightly longer shaft?
   / 3 point hitch question #12
If you buy new then the PTO shaft is usually over length. It is then cut to the correct length. Everything Attachments has a video on how to do it.
Tractor PTO Shafts | The best quality shafts at the best price available and as always free shipping.
If used, the PTO shaft is usually already cut down a bit. However, if there is 6" of engagement of the sliding (telescoping) shaft when it is hooked up to the tractor then it is good to go. Sometimes even with the Pat's system the PTO shaft is long enough to work safely.
Tractor Supply also has replacement PTO shafts but they don't come cheaply. That is why the extension (adapter) in my previous post is a good choice for used equipment with a PTO shaft that is slightly too short.
Tractor Supply Co. - Enjoy searching:pto shaft
Thanks for the info. I'll have to keep that in mind when hooking up the shaft. I was wondering what the safe amount of travel the shaft needed.
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
Booster Cables (A59230)
Booster Cables...
