3 point hitch wont decline
   / 3 point hitch wont decline #1
danburt
Branson 4020
I am a new tractor owner having bought a branson 4020 two months ago. but today i hooked up my rotary cutter to the 3 pt hitch and after i raised the unit and travelled to the field the 3 point hitch would not decline (only very slowly by gravity). i am very new to tractors and any help would be greatly appreciated. thanks in advance Daniel Burt
   / 3 point hitch wont decline #2
Tractor should have a knob or lever somewhere around 3pt lever & seat. This knob determines speed of 3pt motion. Sounds like it's closed off.
Have fun.
   / 3 point hitch wont decline #3
Barry is onto it. There is a knob on the panel between the seat and the floor that turns one way to open and the other to close. It controls the rate of descent of the three-point. Sometimes kids will turn the knob in a little (or a lot) and the next time dad gets on the tractor he has trouble.
   / 3 point hitch wont decline #4
barry is most likely right. I gone out on a few service calls just to open the valve a little bit.
   / 3 point hitch wont decline #5
yep, look for a knob under the seat, and turn it in the direction the arrows indicate. That controls the speed of the 3 pt.
anthony
   / 3 point hitch wont decline #6
One other possibility that I have seen a couple times on Bransons and on an Iseki: If you open the valve and the three-point still won't decline, then unhook the implement, put the three-point lever all the way down and shut off the tractor. Then go to the back and lift up on the arms a few inches and slam them down sharply. If the pressure relief valve is stuck, you will hear a click and the arms will work correctly.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
2012 John Deere 6170R (A57148)
2012 John Deere...
