3 Pt. Backhoe
   / 3 Pt. Backhoe #21
I picked up a 757 a few years ago from a TC40. Came with the subframe, but no mounts or brackets, nothing extra. Took a bunch of pictures of the original parts on the guys TC and fabricated up quick mounts for my old 1966 3400. Ended up with a great setup that works well and is real tough too! Sub frame is the way to go!
   / 3 Pt. Backhoe #22
Glad everything worked out for you :) . Think You will be happy with the set up and " Feel " since it is more attached to entire tractor .
Fred H.
   / 3 Pt. Backhoe
Well, my Liberty backhoe finally arrived, about 6 weeks later than promised. I uncrated it Saturday and hooked it up off my 3 pt. Did a 100 ft. ditch Sunday and it runs well. Now I'm going to dis connect it and put my subframe on and figure what kind of brackets I need. If I set this down with bucket and outriggers extended will it set there okay or do I need to make some kind of rack?
   / 3 Pt. Backhoe #24
Should sit there fine presuming that the liberty has a pin to prevent the boom/dipper from moving from cylinder bleed down when being stored
   / 3 Pt. Backhoe
Yes, it does have a pin for the boom, I had not thought of that. Thank You!
2016 Ford F-350 (A56858)
2016 Ford F-350...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
