3 pt. boom arm design
   / 3 pt. boom arm design #11
Yeah, that would be just like the braces on top of the commercial tubular booms - and since it is in tension, you could use chain, too. It'd be even better if you could add a couple diagonal braces on the bottom, too. Did you ask the maker about side forces? I just emailed and asked what his opinion was, for the heck of it.
   / 3 pt. boom arm design #12
Those guys do answer their mail quickly. Used the Email address provided above. For what it's worth, here's what they said:
<font color="blue">"Haven't had any problem with angle twist. However, we have substituted 2x2 tubing upon request." </font>
I still like the clean, multipurpose design, even though I'd go with 2x2 square tubing, and a top chain for my stiffener.
   / 3 pt. boom arm design #13
Here's my home made boom pole. The boom is a piece of 2" schedule 40 steel pipe. The bracing is of angle that was lying about, and the bottom bolts to a drawbar. The reinforcement on top is 1'2" square stock, and the attachment for the chain is a pair of Unsitrut "L" braces welded to the pipe. I can lift the front of the tractor if I'm lifting something too heavy.
The rig chained to the pole is a thing I made up to fix my stone driveway before it was blacktopped. Simple matter of bolting two pieces of 6" beam together. The two chains connecting to the 3PH get lengthened/shortened to cast material to the left, right or straight. They are off-center, and flipping the rig allows it to be more or less aggressive.................chim
   / 3 pt. boom arm design #14
Chim....did you bend that sch. 40 pipe ??? If so...did you use a bender or do you have a trick to share.
   / 3 pt. boom arm design #15
2500 to 3500 lbs - make sure your tractor can handle the load. I have a L3450 with an SMC FEL. I used my boom pole to move a mill/drill (about 800 lbs) and had to put all my suitcase weights into the front bucket just to keep the front end down. I think that my 3 pt hitch is rated for 2500 lbs at the pins and then is de-rated as the load is further away from the pins.
carl
   / 3 pt. boom arm design #16
i am pretty sure my tractor should handle that kinda weight at about 4ft out from the lift pins,i have lifted a nissan pickup with my 3pt pallet forks,with the extensions slid on them. im sure that truck had to weigh around 3500lbs and the front stayed on the ground fine. if i wanted to lift more than that i would probably need to get some weights for the front but for now its been fine, i am looking to add some weight to the front tho at some point, im sure the safety patrol will be on me for lifting heavy loads without counterweight but i think it was safe
   / 3 pt. boom arm design #17
Yep, bent it at home. The trick was placing a $9.43 sealed bid on an old conduit bender at work years ago. It's a manual hydraulic bender that you need to pump with a "porta power" type hand pump. It'll bend up to 4" schedule 40 into a full 90°, although pipe larger than 2" needs to be bent in segments (or shots) of lesser degrees. I just placed the bid on a whim, thinking it would come in handy. To be honest, I can't remember how much I bid, but it was around $10, and I went with odd cents just to get a laugh from the guy opening the bids.
I rarely use the bender because I can tell a guy in the shop what I need. He can punch the info into a computer, and voila! it's done. It is handy to have for the occasional "need it now" or odd job. I bent a 1" shaft on the RFM a while back, and rigged the bender up like a press to straighten it.
Most electrical contracting firms have electric/hydraulic bending equipment that would do this in about 10 seconds..............chim
Millcreek 5ft 3 Point Aerator (A59225)
Millcreek 5ft 3...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
Runs and Starts (A59228)
Runs and Starts...
BOMAG BMP 8500 TRENCH COMPACTOR (A52709)
BOMAG BMP 8500...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
