3 pt hitch log splitter on 3940 hst
   / 3 pt hitch log splitter on 3940 hst #41
V1 Buzz , I looked up the hydraulic specs on your tractor, you'll have no problem on your tractor... you can get a larger unit like the powerhorse or split fire 20 T... I have seen guys who made bucket mounts for their splitter too...
Exactly, I plan to mount my splitter to my loader bucket, connect to my front auxiliaries. Split directly into the bucket and dump wood when full without even removing splitter. I can set splitter work height with loader. I can load large logs into my pickup bed or other structure with loader or backhoe(with thumb) then place loader mounted splitter at same level as bed or other structure and roll large logs onto splitter.
BTW where did you get the 5.45 GPM spec? you should have a lot more than that...
5.45 is the flow rate of the auxiliary pump, spec. directly from the OEM JD 110 operator manual. I believe there are at least three pumps on the machine with varying capacities.
   / 3 pt hitch log splitter on 3940 hst #43
Renting a splitter once a year works best for me. I can do about 5 or 6 cords in one days rental and that is enough for most of my heating needs. I pick up the splitter at 3 pm, can usually split a little that evening before dark, split all day the next day and then return it by 9 am in the morning. The rental is $111. That's a 9 year payback on a splitter that costs a grand. Plus your money is in the bank rather than invested in a splitter that sits most of the year. Its a no brainer financially as far as I am concerned. No maintenance or storage and the rental shop usually has a newer model too.
   / 3 pt hitch log splitter on 3940 hst #44
I was doing the same but now that I'm older my body likes doing a cord or so a day and then taking a day or two off. I'm sure I could still do the 6 cord (3 for me and 3 for my step father and mother) but I've changed my habits. Now I block up enough to fit my side by side and trailer, move it to the splitter, split it, then stack it. It breaks things up. I don't regret renting one for years, that just means mine will last that much longer. But I'm also glad I have a splitter now and can go at my pace.
   / 3 pt hitch log splitter on 3940 hst #45
You can rent tractors as well. I'd be willing to bet it would be a no brainier financially that you would be money ahead to just rent the tractor when needed.
   / 3 pt hitch log splitter on 3940 hst #46
I bought my chinese 37 ton splitter off of ebay about 5 years ago. Before I had a tractor. I can tow it around with my atv or push it in and out of the shop by hand. Uses regular gas and fits the bill for me. I had to assemble it but it was only $1600 delivered and is a life saver. Some of our hardwoods have been down for over 4 years and are like petrified wood. I don't think I would have done it differently even if I already had a tractor.
   / 3 pt hitch log splitter on 3940 hst #47
The recent purchase of my machine and near future purchase of the supporting splitter will be for reasons not directly related to economics. I went over my target budget purchasing the JD 110TLB. However, at time of purchase, it was the most loaded 110 TLB in the northeast. It has front and rear auxiliary hydraulics, quick release backhoe bucket with thumb, heated cab, 72" digging bucket, 88" snow bucket and formal quick attach adjustable 48" forks. The cab protects controls and gauges for outside storage. It's a big enough machine that I can move and lift nearly anything short of whole vehicles.
My latest handling of firewood is on pallets. I take sturdy full-size whole pallets, add vertical 2x lumber and cross brace across top. I stack cut and split wood on these, shy of half a cord, but still a lot. At any time, I can grab these with the machine and forks, move a lot of wood quickly and it stays stacked the whole time.
Running the future splitter of the front auxiliaries may not be utopia but I see it as follows. I can hang splitter in/on bucket. I can set split height to nearly wherever I want. All split wood falls directly into bucket. Once bucket it full, I can bring wood to wherever and either dump or stack and not remove splitter, repeat process.
I burn less than four cord a year. I'm not too concerned about running up hours on machine and use of the machine is very intermittent. To fire it up to run the splitter occasionally would be good to keep the lubricants flowing.
Operation and purchase of either machine or splitter may not be most cost effective, especially in regard to rental. However, my time and convenience get worth more and more to me every day. The ability to fire up machine with or without splitter, any time, any day, for fifteen minutes or a whole day carries tremendous value to me.
   / 3 pt hitch log splitter on 3940 hst #48
Open to suggestions.
   / 3 pt hitch log splitter on 3940 hst #49
Absolutely!!!:thumbsup:
   / 3 pt hitch log splitter on 3940 hst #50
I don't think you'd be happy with a 3 pt splitter with only 5gpm. It would make for a very slow cycle time.
I have now split several cord with the setup. We have the DR 3PH with 3" bore. There have only been three pieces of wood that stalled the splitter, two pieces of Elm and a very large piece of knotty oak. I just reset them to another position and I tackled them.
I'm running the splitter off the front auxiliary ports, rated at 3000 PSI, 5.45 GPM. I run the machine @ 1500-1600 RPM. My cycle times are six second extend and five seconds retract. I haven't tried other RPMs and clocked it. I'm very pleased with the cycle time and comfortable with the RPM.
I prefer to have someone else run the handle as I load and unload, but I have run by myself. I usually have my wood efficiently staged, very large stuff on the tailgate/in pickup bed with splitter/trays parked within a foot of the gate. I put wood in back of pickup with loader, then setup up splitter adjacent to so I can roll logs onto splitter, no manual lifting.
I'm comfortable to say that I run circles around a single action/single blade splitter based on staging wood, that is by myself or with additional staffing.
1459 (A57192)
1459 (A57192)
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2020 DRAGON ESP...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
