Sprayer 3 pt hitch sprayer
   / 3 pt hitch sprayer #1
Pokeboater
Macon, Georgia
John Deere 4520 cab
I have a 3pt hitch sprayer I want to run from the back of my Kawasaki Mule. It runs off the pto which the Mule doesn't have. Is there an easy way to rig a gas motor to run the pump? I've seen gas motors with reduction gears built in, would that work? Thanks!
   / 3 pt hitch sprayer #2
A gas motor would work, but you will have to gear it down from 3600rpm to 540rpm. A better choice would be a electric pump from TSC or Agri-supply.
I've got one of the electric sprayers and it doesn't put out enough "stuff".
   / 3 pt hitch sprayer #4
What size pump is it and how may nozzles are you running? Maybe the pump is just undersized?
The electric sprayer is a 3.8 gal. The pto sprayer has a boomless nozzle.
   / 3 pt hitch sprayer #6
Generally, the pumps on those electric sprayers are sized to match the tanks they're on. We opted for the 25-gallon 10-foot boom ATV sprayer from TSC (mounted on a KK carry-all), because it had about the biggest pump available. Had no problem running the 10-foot boom. Fiddling around (water only, of course!) with the handgun, it lived up to its claim of being able to shoot over 40 feet. I would imagine the pump on a 3.8 gallon tank is gonna be quite small (shoot, that tank is smaller than our backpack sprayer).
I wasn't clear, the PUMP pumps 3.8 gal per minute. The SPRAYER holds 35 gallons.
1994 Club Car Electric Cart (A56859)
1994 Club Car...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
2006 APPA TL (A55787)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
