3 pt Log Splitter: PTI. Hydraulic or stand alone??
   / 3 pt Log Splitter: PTI. Hydraulic or stand alone?? #11
thanks. Just getting ready to pull the trigger on one and I am just a little worried on the cycle time. I am sure it will be plenty fast.
   / 3 pt Log Splitter: PTI. Hydraulic or stand alone?? #12
Yes, its listed at 4.8 GPM. I know it works as fast as I can.
Chris
   / 3 pt Log Splitter: PTI. Hydraulic or stand alone?? #13
i always have a lot of steel around, so last year i built my own. i have a large wood stove and a medium fireplace insert. the max i can burn in the fireplace insert is 18", so i do all my wood at 16". i went with a 18" cylinder and that helps on cycle times a lot. there's no excess to take up like there would be on a 24" cylinder. i mounted the cylinder so there's 19" between the ram and wedge.
i had looked at the little 2-way 3ph splitter sold by northern, and they rate it for either 12 or 14" logs, so its a safe bet it will do that and probably a hair more - with only a 3" cylinder. most splitters are 4" (or larger now) cylinders, but in the interest of cycle time and the fact that i don't end up with a lot of wood over 16", i cut down to a 3 1/2" cylinder. smaller diameter = less fluid needed to fill.
for power, i used the remotes on my tractor: jd 770 with 5.6 gpm flow. i'm sure there are faster units, but by shortening the stroke and cutting the diameter of the cylinder, this thing cycles as fast as a one man operation can split.
i was considering building the splitter so it could go either horizontal or vertical, until one of my uncles looked at me funny and asked why i wouldn't just lower the 3ph instead. apparently all my years of designing failed me at that point. just build your splitter so the top & bottom pins are the same distance apart as the tractor, and you will be able to adjust the height as needed from ground level to 3 feet high with the lever on the tractor. drop it to the ground and roll the heavy pieces on to split, and put it at a good working height for the light stuff.
   / 3 pt Log Splitter: PTI. Hydraulic or stand alone?? #14
I am looking at splitter to attached to my 3 pt hitch. I see there is PTO and Hydrualic available. This looks a lot handier that a stand alone unit you drag around on wheels. Why by a honda motor when you can run it off the hydraulics?
Verticle vs horizontal ? or get one that does both? My PTO does 12 gal/min so I assume I need to keep this in mind when purchasing.
I got a 20 ton ***. Log splitter from ram splitter three point hook up made it in to a stand alone Doug set me up with a princes pump my 1528 run on ideal 4 to 6 hour for 5 days on one tank of fuel. It has never let me down. They are building me a firewood wrapper now. You call Doug at Ramsplitters tell him what you need he will help you with it.
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
Water Pump (A57454)
Water Pump (A57454)
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
