3-Pt Log Splitters - How Fast?
/ 3-Pt Log Splitters - How Fast? #1
Argonne
Paris, TX
JD2210, Ford 4400, Case IH 685, Terramite T7, JD 6x4 M-Gator
I'm in the market for a log splitter. I like the idea of a 3 pt splitter so that I can take it to the woodlot on the tractor, and I should be able to take advantage of the tractor's power and save money on a power source (and one less small engine to winterize every year).
There seem to be 2 types out there. Those that run on the tractor hydraulics, and those that have a PTO pump. The PTO models seem to be hard to find, and are expensive when you do. I'd like to keep the price under $1k.
I've found two models with attractive price tags and the power to split the Osage Orange I'm splitting. The Northern Tool offering, and the Ramsplitter.
The technical information on both is sketchy, but I e-mailed Ramsplitter and they say that with a 6 GPM pump on the tractor, the cycle time is about 20 seconds. The Northern Tool model has 3/4 the power at 15k tons, so I suppose it's cycle time is a bit faster.
So here's my question (finally). I have no experience with log splitters and I'm wondering about the significance of the cycle time spec. When they say that the cycle time is 20 seconds, is that the time it takes the ram to fully extend, extend and retract, or what? Also, when splitting logs, is it typical to need to make a full cycle, or is the job typically done in a half cycle or something?
The reason I'm so interested is that my JD2210 only has ~3 GPM available, and even if I go with the smaller Northern Tool model I'm having visions of having time for a coffee break between each log split. If so, I might need to spring for the expensive PTO type, or bite-the-bullet and have another small engine to babysit on a standalone model.
Any education anyone could give me on the subject would be appreciated.
/ 3-Pt Log Splitters - How Fast? #2
JD says your 2210 has a 5.5 gpm pump, but makes no mention of remotes. You're not going to operate either splitter on 2210 hydraulics without somewhere to connect the hoses. A TPH splitter with it's own pump only requires PTO power from the tractor. What you have to do is weigh the cost of adding a pair of hydraulic remotes to the 2210 against the cost of the PTO driven splitter.
I have a new 22 ton Huskee that is powered by tractor hydraulics, but never actually timed the work cycle. Even with the tractor at half throttle (~1200 rpm), the return time is faster than I can get the split piece off and put a fresh section on. The piston is almost always sitting there waiting on me to get the next log positioned. Next time I split, I'm going to back the engine off to ~1000 rpm, maybe then I can keep up with the splitter work cycle.
By the way, my Huskee didn't come with hoses or QD fittings either. You should probably factor that into your cost comparison too.
One other thing, the splitters you linked to were horizontal only. I can tell you that a horizontal/vertical is positively worth the money if you split anything heavy. I tilt the splitter vertical to split everything over 50# first. When the big chunks are all down to the weight limit my back will tolerate, I flip the splitter down to horizontal and go back to work.
//greg//
/ 3-Pt Log Splitters - How Fast? #3
A gallon is 231 cubic inches. A 4" piston has 12.566 square inches of surface area. Multiply this by the length of the stroke and you have the volume of the cylinder in cubic inches. A 4" X 24" cylinder will have a total volume of 301 cu in. At 3 GPM that is 693 cu in of fluid so it will take a little less than 30 seconds to fully extend. Retracting will be a little faster as the rod side of the cylinder has less volume due to the area occupied by the rod.
Depending on the type of wood and moisture content you will usually not have to extend the ram all the way to complete the split.
I'll be installing auxilliary hydraulic connections on the tractor soon to serve another implement, but I haven't yet looked into exactly how to do that. I'm not sure how many GPM I'll have available when I do, so I chose ~3GPM as a worst case scenario.
How many GPM do you think you're feeding your Husky at 1200RPM?
/ 3-Pt Log Splitters - How Fast? #5
I can only guess, one or two maybe ? But it's academic, the flow goes into bypass when the lever returns to the center detente. The point is to adjust the engine rpm to the best compromise between splitting power and cycle time. And obviously lower RPMs translate into lower fuel consumption.
Same with the PTO driven ones too I would assume.
And unless you have some reason to install flow restrictors, the gpm at the remotes should be the same as at the pump.
//greg//
/ 3-Pt Log Splitters - How Fast? #6
My experience is that slow cycle times are a major aggravation. I have a 13.5 gpm 2-stage pump on my tow-behind splitter and with a 4" x 36" ram cycle time is maybe 12-14 seconds, and I still wish it was faster. My old setup with the same splitter was a 22 gpm Prince pto pump on an old Farmall A and that was better though it stressed the 18 hp Farmall a little in an elm knot. Do the math like Ron says, and get yourself a fair gpm figure for your tractor. If it's going to be 15 seconds or more you might not like having spent the money for the remotes if you don't need them for something else. That said, it's still easier than swinging a maul! Jim
/ 3-Pt Log Splitters - How Fast? #7
I looked at 3PH splitters before I purchased a stand alone unit. One model was a TimberWolf with a PTO driven hydraulic pump. The PTO driven arrangement had faster cycle times than the tractor's hydraulic driven one and no remotes were necessary.
That splitter sold for a few hundred dollars more than their stand alone unit.
As far as cycle times go it depends on how much wood you are going to split in a season. If you are going to split 6 to 8 cords of wood then 20 seconds to go from the retracted position to the advanced position and back is not really a big deal.
The hardest part is psychological, when you are splitting wood that with one or two hits with a maul does the job in 6 - 8 seconds. However, when you get to those pieces that are mean to split and you watch the splitter muscle its way through 20 seconds is not much time.
The one draw back to a 3PH splitter is how far behind the tractor it extends. For me I would forget to allow for this length and end up whacking something with it. Most stand alone units are on wheels so you can still tow them places and use the tractor to bring wood to the splitter or have a trailer to haul split wood away.
Storage of a stand alone unit is easier and you can move it out of the way when necessary.
Randy
/ 3-Pt Log Splitters - How Fast? #8
Argonne,
I have a BX2200 and considered a hydraulic log splitter. From input on TBN and other research it did not seem like a good idea. The GPM just isn't there.
I then considered the IRON AND OAK PTO log splitter. But as you noted the PTO splitters are expensive. The one I linked to is almost $1800.
I like splitting by hand but usually once a year we rent a splitter. Costs me about $60 for the whole day. My wife, daughter and I can process a whole lot of wood in one day.
For us the rental option works best.
Phil
/ 3-Pt Log Splitters - How Fast? #9
</font><font color="blue" class="small">( The one draw back to a 3PH splitter is how far behind the tractor it extends. )</font>
Not so with the horizontal/vertical models Randy. Click on the link in my earlier post, or the Iron & Oak link below yours. You'll see that the more versatile horizontal/vertical models mount "sideways" on the TPH.
And I never measured either, but I can't help but wonder if a pull behind doesn't extend just as far behind a tractor as does the TPH type you describe.
//greg//
/ 3-Pt Log Splitters - How Fast? #10
Like you Argonne I wish I had all kinds of attachments on my 2210. I could have used a grapple for the pine I cut down and demolishing my old deck to the burn pile. Also would like a woodsplitter to replace my tow behind I just sold. I didn't need the tow behind taking up space and was lending it out more that I was using it. I don't burn more that a cord/year.
Check out Markham welding, I believe they have a splitter for a Bob Cat that might be something to modify/mount in place of the 2210 bucket. I am seriously thinking of adding an electric selector valve on my 2210.
/ 3-Pt Log Splitters - How Fast? #11
Argonne,
Have you considered a splittng maul/axe. A good one goes for under $50. No hydraulics. No PTO. No winterizing. /forums/images/graemlins/grin.gif
Seriously. I have split almost 3 cords over the last few months by hand. I spent a summer working over a log splitter when in high school. Never again will I do this. My back ached and ached. Splitting my hand you are moving around and your body is not bent over all of the time. It makes a huge difference. I timed myself the other day and I could split and stack about 1.5 cf of wood in 5 minutes or a bit less. And I make small pieces. I try to have the "sides" of the wood no longer than 3 inches if that make sense. So I'm not just splitting a 15" diameter round into 4-5 pieces. If the wood was a REAL tough that is when a log splitter wins.
IF I have bought a log splitter it will not be powered by the tractor. I want a stand alone unit so I can build a bench to hold the splitter. That way I can use the tractor to lift the rounds to the splitter and stand up straight not bent over for hours and hours.
But right now the hand splitter works. /forums/images/graemlins/grin.gif
Later,
Dan
/ 3-Pt Log Splitters - How Fast? #12
If you are working alone, cycle time is not as big an issue. By the time you get the pieces off and bend over to pick up a new piece, the head will be back in position. If you have help, then cycle time can be a big issue. Depending on how you divide up the activities, the person operating the joystick can terminate the cycle before the head returns to the home position, and thereby shorten the cycle. As has been explained in previous replies, faster cycle time means a bigger pump... meaning the more expensive.
I cut, split, and delivered 90 cord of firewood last year. I chose to use a standalone splitter with it's own engine. That way I can use the tractor to move wood around while the splitter is being used. I bought a slightly used 26 ton splitter on EBay for under a grand.
/ 3-Pt Log Splitters - How Fast? #13
I built myself a PTO powered splitter a couple of years ago. One suggestion I can make to you, regardless of which type you decide to buy, is to put it on wheels so you can move it around by hand. It seemed that no matter where I parked mine, I needed to move it somewhere else in between the times I needed to really use it. That meant backing up to it, going thru the 3pt hookup routine, only to move it to another parking spot and unhitching it. A real PITA. This year (I'm a slow learner...) I put some tricycle-type running gear under it. Big improvement. I did the same thing to my BIL's splitter, and one for my SIL as well.
As far as speed is concerned, my splitter is cobbed up from all kinds of parts. I'm using a short PTO shaft to drive a right angle gear box off of an old Ford 8N cordwood saw. On that, I modified a Chevy 2 belt crankshaft pulley to fit on the gear box to drive a hydraulic pump I bought off of eBay. This contraption drives a 3x24 tie rod piston I had given to me. The cycle time takes about 20 seconds with the tractor running at a fast idle. That seems to be about perfect for me. A few years ago it would have seemed a little slow, but at my advanced state of maturity, it's about right /forums/images/graemlins/smile.gif.
My BIL has one of those Northern Hydraulics 3 pt splitters run by tractor hydraulics. He powers it with his Ford 1320 tractor. It's a small tractor. I don't know what the hydraulic GPM is, but it seems to run about the same time as mine. My SIL has a home built stand alone unit. It cycles in about 10-12 seconds. The extra speed is nice, but to me it seems too fast. A friend of mine is missing a thumb, after squeezing it off in a splitter a couple of years ago /forums/images/graemlins/frown.gif. He said it happened so fast he didn't feel it until it was too late. I think I like my slow splitter just fine...
Corm
/ 3-Pt Log Splitters - How Fast? #14
you might want to check out the splitters at supersplit.com - these are stand alone and really quick cycle times. the 6 hp mode has a 2.5 second cycle time. 2 sec out, 1/2 sec back. they are rather pricey, but thought you'd like to know about one more option. they don't run on hydraulics at all.
/ 3-Pt Log Splitters - How Fast? #15
I have a 3PH wood splitter that is powered by the tractor hydraulics. My pump runs about 9Gal/min into a 4" x 24" cylinder. The stroke time is about 10 sec, and to me that is slow. The only reason I have the unit is because it came with the tractor which came with the property I bought.
I only use it about once a year to split wood for my own consumption. I usually split about 2 cords per year. If I didn't already have a splitter I think I would either find one to borrow or rent one. For my purposes the economics just aren't there.
/ 3-Pt Log Splitters - How Fast? #16
I purchased a three point splitter from Northern Tool about 3 weeks ago. I have it attached to my TC40DA. The tractor I believe is rated at about 10 gpm of hydraulic flow.
For me the decision to try the Northern Tool splitter was an easy one. Northern hands out shopping bags at the Minnesota State fair that have $75.00 coupons (for purchases over $500.00) for use at their retail stores. The splitter retails for $499.99 so I was able to purchase the splitter for about $425.00 plus 6.5% sales tax. THe splitter does not come with hoses so I had my NewHolland dealer make be up a couple of 4 foot hoses for $25.00.
I agree with some of the other posters here that having a stand alone splitter would be handier at times. It only takes about 3-4 minutes to hook it up. But it would be nice to have a stand alone unit so I could pull it to the wood pile with the garden tractor.
I originally purchased the three point splitter to avoid having another gasoline engine to maintain. When diesel fuel was cheaper than gasoline I figured fuel consumption would be a factor. However, with diesel fuel a buck more than gasoline perhaps this become an issue. Then of course there is the issue of putting extra hours on the tractor. My NewHolland dealer figures about $5-7 per hour for depreciation. So the 10-20 hours per year spent splitting has a cost.
/ 3-Pt Log Splitters - How Fast? #17
greg, The picture of the Iron Oak splitter is impressive and very compact. The Timber Wolf 3PH splitter I looked at extended straight behind the tractor and had no stand or feet to set it on when not attached to the tractor.
I still like my stand alone especially the 4 second cycle time.
Randy
Thanks everyone for all of the comments. After reading them I'm leaning away from a 3-Pt splitter. Being about the most impatient person I know, I suspect that the cycle time in particular (with my puny GPM rating) will drive me nuts. I think I'll shift my focus to powered units and keep shopping.
/ 3-Pt Log Splitters - How Fast? #19
Be carefull of RamSplitter. I started a thread about electric log splitters here . Ramsplitter was on my short list for their 12 ton electric splitter... until someone else chimed in with some bad experience. It seems the trucking company called him and said the unit they received had significant damage. He refused delivery and contacted Ramsplitter for a replacement or a refund. They never returned calls or emails. He eventually contacted his credit card company and had the charges reversed.
Thinking this may have just been a fluke, I ordered a report from the Better Business Bureau on them. There was only one report on them. It was very similar... customer had a complaint/problem, was unable to get a response.
Thinking I might still go for it, I sent an email with a few questions on specifications. I got a form letter back saying "A sales representative will follow-up on your request right away!". I never heard anything further, even after leaving two phone messages on their answering machine.
They may make a good product. I can't say, having never seen one. But this has raised enough red flags for me. If you do order, I suggest a credit card where you have some options to get your money back if there are problems and they don't respond.
John Mc
/ 3-Pt Log Splitters - How Fast? #20
</font><font color="blue" class="small">( After reading them I'm leaning away from a 3-Pt splitter. )</font>
Here's one more, a little after the fact. I picked up a 3 PH spitter last year, because my wrists are giving out from using an axe too much for work. The price was right (free) and I run it off the pump for my backhoe. But it's a pain because either I'm skidding trees out as I'm putting up the firewood,so my winch is on; or I want to offload into the bucket on the other end of the tractor. If I was buying, I'd definitely go with a free standing unit.
2018 Mitsubishi Eclipse SUV (A66738)
2018 Mitsubishi...
2007 WESTERN STAR 4900 SB CRANE TRUCK (A67714)
2007 WESTERN STAR...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
2022 PETERBILT 579 6X4 T/A CAB AND CHASSIS (A69167)
2022 PETERBILT 579...
