3 PT Quick Connect on a 8N
   / 3 PT Quick Connect on a 8N
Well, I installed them on the old 8N this afternoon. Instalation was not as straight forward as it looked because the stabilizer bars kind of got in the way, but I put them on the best I could figure.
The bushings that came with them were about 1/8" to long to let the linch pins go in, but a little grinding and they worked.
I've gotta say, I was happy, happy, happy while playing around swapping implements around today playing.
We'll see how they hold up.
   / 3 PT Quick Connect on a 8N #12
post some pics when you get a chance!
Sorry it took so long to post some pics.
I've been happy with these so far. They were simple to install, but some of the bolts really don't do much of anything in this application. Also the very bottom bolt was to short to be able to use the jamb nut. Here's a few pics. If anyone see's something that I didn't install correctly or something that I can improve on (other than that lower bolt) please let me know.
These two bolt hit each other....
   / 3 PT Quick Connect on a 8N #14
It seems like someone would just make replacement arms with better hookups, at least for the popular models
Might be a good niche to fill in the marketplace for someone with the ability and machinery.
I'd probably buy a set.
   / 3 PT Quick Connect on a 8N #16
Maybe it's just my technique, but changing from one to another kicks my tail sometimes.
I grew up on a farm watching my grandfather fight with implements with a pinch bar, 2x4 and generally just kicking the crap out of things getting them to line up. That's pretty much what I'm doing now and was hoping for a better way without having to spend a bunch of money.
After I get the land cleared up (less than 1/2 acre), I'll have very little use for the tractor. Maybe I'll just have to work on my technique and learn a few new cuss words until I get this land cleared off. I might still look into the lower quick hooks for the sake of my sanity. After all, I'm still in for less than $200 for the entire set up including a carb rebuild and tune up.
In your case, I'd suggest the Pat's Easy Change.
The biggest hassle in hooking up implements is the lower links...after that, it's pretty easy. The Pat's system, which I had on a Deere 790 for 5 or 6 years, is the most versatile. I doubt you'd find any implement the would require modification, but you will have to get off the seat to hook up the top link.
Like quick hitches, the Pat's system extends the implement back about 4". You may need a PTO extender (Agri-Supply calls them PTO adapters and they cost $20) for PTO driven implements.
   / 3 PT Quick Connect on a 8N #17
They look great! I think that you are going to really enjoy using them, and the time it saves. It's nice that they include the wire loop to hold the hitch open when you are hooking your equipment up. I have not had mine budge at all, and I have had some very heavy, and jarring loads. hope that you enjoy them!
   / 3 PT Quick Connect on a 8N #18
nice finish!
   / 3 PT Quick Connect on a 8N #19
Spotco:
Thanks for the pictures. It makes it easier to see how these things attach. Not at all what I expected.
2022 John Deere 5055E (A60462)
2022 John Deere...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Enclosed Service Truck (A55788)
Enclosed Service...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
