Treemonkey1000 said:Why grind stumps when this stuff works pretty quick.. Might irritate the neighbors though.
Ethylene glycol dinitrate, 70% and Nitroglycerine, 30%![]()
1 or 2 sticks under a stump light the fuse and run like crazy
n92687 said:I actually had pines cut on 3 acres, but now I am just trying to clear 1 acre and prep it for planting. Trees were 8-10 in diameter. It is a mess, but I figure if I can clear the acre of stumps and let mother nature take care of the other stumps on the other 2. I can use the other 2 acres later.
I received a quote of $150 per day for a rental. That it probably the way to go. $5000 is far too much. I thought they might be about $1500. Then it would be well worth the investment to have it sit around after I am done.
JOhn
daBear said:To the other post about using 28% nitrogen - why not just use pure amonimum nitrate? Isn't that 100% nitrogen???
Charlesaf3 said:we aren't oversupplied with corn farmers, but I'll drift by and ask. Most stuff is bought off island in any case. And most farming is organic - don't know if that makes a difference.
reg said:That post hole digger on your avatar...
Just wondering if there are wood boring bits (augers) available for that kool tool.
It seems a few cuts of 6 or 9 inch diameter holes through a stump would make it much easier to destroy with say a bucket edge or box blade ?
Might be able to just reduce the whole thing to holes
I recieved a quote of $150 per day for a rental. That it probably the way to go. $5000 is far too much. I thought they might be about $1500. Then it would be well worth the investment to have it sit around after I am done.
JOhn
wedge40 said:I've always wondered about that also. Take a PHD and just put holes a few feet from the stump to rip through the roots, then pop the stump out.
Wedge
