3 pTH lifting pins
/ 3 pTH lifting pins #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
I did a search but found nothing.
The lifting pins on an implement ......can they be mounted facing in rather than out . Seems with my chains on the tractor the implements spread the hitch too far and the odd link bangs the frame stabilizer. If I could face them in I would have loads of room then to lock the swap bars.
/ 3 pTH lifting pins #2
They work fine pointed in, makes it a lot easier to hitch up. I run tire chains on my B8200 Kubota and have clearance issues between the lift arms and stabilizer chains with them pointed outward.
I now have a quick hitch and added inward pointed pins on the qh, now I switched all the pins back to pointed outward on the implements. If you want to see how I did it I can post you a pic.
/ 3 pTH lifting pins #4
The lift arm pins can be mounted inward or outward.
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
WACKER NEUSON LTW20 LIGHT PLANT (A63569)
WACKER NEUSON...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
15K PARTEK TRIPLEX PUMP (SHOP BUILT NONE TITLED) (A63569)
15K PARTEK TRIPLEX...
240156 (A56859)
240156 (A56859)
