3 Rear Remotes: Worth It??
   / 3 Rear Remotes: Worth It?? #21
Glowplug
I have 3 factory type remotes on my Kubota bought with the tractor. I have 1 that is teed with QDs to front for attachments on the FEL and also to the back for use there. I only have a hydraulic top link now but plan on a tilt cylinder in the future.
I have a tree shear attachment for the FEL that requires two circuits; open and close the shear plus the ability to rotate the shear head. This is quite a tool to cut off trees to 8" plus heavy duty pruning up to about 14'
Vernon
   / 3 Rear Remotes: Worth It?? #22
I have no rear remotes on my caseih dx40 but want to add at least two. The cost seems unreasonable, about $535 for one. Have not priced two or three. I am looking for somebody besides caseih to buy the parts from. I would appreciate any information.
   / 3 Rear Remotes: Worth It?? #23
Good luck. Factory remotes are only available from the manufacturer as they are integrated into the tractor. I think New Holland might have some as your tractor and the TC40 are the same but I would bet the price is now about the same. You could always go the aftermarket route with say a Prince SV valve and get 3 spools for less than $500 complete including hoses and fittings.
   / 3 Rear Remotes: Worth It?? #24
Anyone know how to add one to a NH 2120. There is one rear now and it looks like a stack valve with a end plate. I cant make heads of tails of the parts book. They seem to call about 6 different accessories "remote hyd" and none of them look like a valve stack that one would simply stack up.
   / 3 Rear Remotes: Worth It?? #25
Gee...am I the only one with FOUR rear remotes on a small tractor? :eek:
In my case I use three frequently, since I have two tilt cylinders, and would have use for all four if I had a angle cylinder on my rear blade...hydraulic lift on my box blade scarifiers, and so on.
Like many, I would advise getting more rather than less, if cost is not too much of an issue.
Up until now I couldn't really see the utility in 3 remotes. I am definitely interested in eventually setting up a top 'n' tilt system. Besides, I have always been into overkill. The more remotes, the better. In fact, I think I want MORE than 3 remotes!! I have checked out and researched some tractors. Now I think I will get a New Holland TJ530. I would get the optional megaflow hydraulics and optional rear remotes. Let's see. . .9 rear remotes, 94 GPM hydraulic flow rate, and 530 hp!! I think that should do it.;) Talk about overkill. That's one for you horsepower junkies!!
Seriously though, I would like 3 sets of remotes. The tractor I have been looking at on my Kubota dealers' lot only has 2. It's a Kubota M8540. I can see where a 3rd would be on the block. I just hope that this is an aftermarket option that can be added by the dealer and not a factory option. Anyone know? I may need to ask on the Kubota forum.
   / 3 Rear Remotes: Worth It?? #27
I can't imagine a tractor like that not being able to have more than 2 remotes that can be installed by the dealed. However, I do not know for certain.
7019 (A47477)
7019 (A47477)
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2017 Caterpillar 326FL Hydraulic Excavator (A55787)
2017 Caterpillar...
2006 Hyundai HL740-7 Articulated Wheel Loader (A55787)
2006 Hyundai...
16' Cattle Guard (A53316)
16' Cattle Guard...
